problem is as soon as it connects to wifi and iot cloud the stream stops
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
WiFi connected
Starting web server on port: '80'
Starting stream server on port: '81'
Camera Ready! Use 'http://192.168.0.106' to connect
***** Arduino IoT Cloud - configuration info *****
Device ID: 6c015ece-bb69-4696-9f4d-d05491cb52ac
Thing ID: 76e76762-a359-4f82-bbf3-3443ca14588e
MQTT Broker: mqtts-up.iot.arduino.cc:8884
JPG: 4016B 58ms
MJPG: 3624B 4ms (250.0fps), AVG: 4ms (250.0fps), 0+0+0+0=0 0
MJPG: 3719B 42ms (23.8fps), AVG: 23ms (43.5fps), 0+0+0+0=0 0
MJPG: 3602B 34ms (29.4fps), AVG: 26ms (38.5fps), 0+0+0+0=0 0
MJPG: 4800B 40ms (25.0fps), AVG: 30ms (33.3fps), 0+0+0+0=0 0
MJPG: 4143B 39ms (25.6fps), AVG: 31ms (32.3fps), 0+0+0+0=0 0
MJPG: 3797B 47ms (21.3fps), AVG: 34ms (29.4fps), 0+0+0+0=0 0
MJPG: 4121B 32ms (31.2fps), AVG: 34ms (29.4fps), 0+0+0+0=0 0
MJPG: 4013B 45ms (22.2fps), AVG: 35ms (28.6fps), 0+0+0+0=0 0
MJPG: 3977B 34ms (29.4fps), AVG: 35ms (28.6fps), 0+0+0+0=0 0
MJPG: 5366B 714ms (1.4fps), AVG: 103ms (9.7fps), 0+0+0+0=0 0
MJPG: 3601B 2ms (500.0fps), AVG: 93ms (10.8fps), 0+0+0+0=0 0
MJPG: 3606B 46ms (21.7fps), AVG: 89ms (11.2fps), 0+0+0+0=0 0
MJPG: 3592B 34ms (29.4fps), AVG: 85ms (11.8fps), 0+0+0+0=0 0
MJPG: 3609B 68ms (14.7fps), AVG: 84ms (11.9fps), 0+0+0+0=0 0
MJPG: 3603B 11ms (90.9fps), AVG: 79ms (12.7fps), 0+0+0+0=0 0
MJPG: 3613B 49ms (20.4fps), AVG: 77ms (13.0fps), 0+0+0+0=0 0
MJPG: 3591B 30ms (33.3fps), AVG: 74ms (13.5fps), 0+0+0+0=0 0
MJPG: 4000B 43ms (23.3fps), AVG: 73ms (13.7fps), 0+0+0+0=0 0
MJPG: 3593B 35ms (28.6fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3578B 45ms (22.2fps), AVG: 69ms (14.5fps), 0+0+0+0=0 0
MJPG: 3610B 34ms (29.4fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3603B 46ms (21.7fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3606B 33ms (30.3fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3592B 45ms (22.2fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3594B 34ms (29.4fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 4000B 46ms (21.7fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3595B 33ms (30.3fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3577B 47ms (21.3fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3593B 32ms (31.2fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3597B 44ms (22.7fps), AVG: 37ms (27.0fps), 0+0+0+0=0 0
MJPG: 3563B 36ms (27.8fps), AVG: 39ms (25.6fps), 0+0+0+0=0 0
MJPG: 3588B 54ms (18.5fps), AVG: 39ms (25.6fps), 0+0+0+0=0 0
MJPG: 3593B 51ms (19.6fps), AVG: 40ms (25.0fps), 0+0+0+0=0 0
MJPG: 3601B 175ms (5.7fps), AVG: 46ms (21.7fps), 0+0+0+0=0 0
MJPG: 3603B 1ms (1000.0fps), AVG: 45ms (22.2fps), 0+0+0+0=0 0
MJPG: 3575B 75ms (13.3fps), AVG: 46ms (21.7fps), 0+0+0+0=0 0
MJPG: 4089B 39ms (25.6fps), AVG: 47ms (21.3fps), 0+0+0+0=0 0
MJPG: 3605B 43ms (23.3fps), AVG: 47ms (21.3fps), 0+0+0+0=0 0
MJPG: 3628B 35ms (28.6fps), AVG: 47ms (21.3fps), 0+0+0+0=0 0
MJPG: 3753B 45ms (22.2fps), AVG: 47ms (21.3fps), 0+0+0+0=0 0
MJPG: 3649B 34ms (29.4fps), AVG: 47ms (21.3fps), 0+0+0+0=0 0
MJPG: 3639B 46ms (21.7fps), AVG: 47ms (21.3fps), 0+0+0+0=0 0
MJPG: 3749B 490ms (2.0fps), AVG: 70ms (14.3fps), 0+0+0+0=0 0
MJPG: 3828B 2ms (500.0fps), AVG: 68ms (14.7fps), 0+0+0+0=0 0
MJPG: 3570B 132ms (7.6fps), AVG: 73ms (13.7fps), 0+0+0+0=0 0
MJPG: 3625B 1ms (1000.0fps), AVG: 70ms (14.3fps), 0+0+0+0=0 0
MJPG: 3433B 71ms (14.1fps), AVG: 72ms (13.9fps), 0+0+0+0=0 0
MJPG: 3534B 14ms (71.4fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3543B 54ms (18.5fps), AVG: 72ms (13.9fps), 0+0+0+0=0 0
MJPG: 3544B 25ms (40.0fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 3565B 84ms (11.9fps), AVG: 73ms (13.7fps), 0+0+0+0=0 0
MJPG: 4951B 10ms (100.0fps), AVG: 71ms (14.1fps), 0+0+0+0=0 0
MJPG: 4408B 76ms (13.2fps), AVG: 72ms (13.9fps), 0+0+0+0=0 0
MJPG: 3726B 28ms (35.7fps), AVG: 65ms (15.4fps), 0+0+0+0=0 0
MJPG: 4000B 59ms (16.9fps), AVG: 68ms (14.7fps), 0+0+0+0=0 0
MJPG: 4000B 20ms (50.0fps), AVG: 65ms (15.4fps), 0+0+0+0=0 0
MJPG: 3697B 43ms (23.3fps), AVG: 65ms (15.4fps), 0+0+0+0=0 0
MJPG: 3717B 36ms (27.8fps), AVG: 65ms (15.4fps), 0+0+0+0=0 0
MJPG: 3723B 49ms (20.4fps), AVG: 65ms (15.4fps), 0+0+0+0=0 0
MJPG: 3730B 30ms (33.3fps), AVG: 65ms (15.4fps), 0+0+0+0=0 0
MJPG: 3784B 63ms (15.9fps), AVG: 66ms (15.2fps), 0+0+0+0=0 0
MJPG: 3921B 59ms (16.9fps), AVG: 67ms (14.9fps), 0+0+0+0=0 0
MJPG: 4069B 3ms (333.3fps), AVG: 42ms (23.8fps), 0+0+0+0=0 0
MJPG: 6275B 117ms (8.5fps), AVG: 48ms (20.8fps), 0+0+0+0=0 0
WiFi status ESP: 3
Connected to "Vijan's"
JPG: 3910B 3ms
MJPG: 3901B 3ms (333.3fps), AVG: 42ms (23.8fps), 0+0+0+0=0 0
[E][camera.c:1483] esp_camera_fb_get(): Failed to get the frame on time!
Camera capture failed
Connected to Arduino IoT Cloud
