ESP32-CAM fails to start-up repeat message
I've been building various projects with the ESP32-CAM AI thinker module. I have been doing this for a while now with no problems. Recently I changed my PC to a newer one with Windows 11and installed Arduino IDE from scratch.
I then took an existing working module and added code that allowed OTA programming.
The module is removed from the board and programs ok. When I plug it back in I get this error message repeat ad infinitum.
assertion "state == EntryState::WRITTEN || state == EntryState::EMPTY" failed: file "/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/nvs_flash/src/nvs_page.cpp", line 339, function: esp_err_t nvs::Page::eraseEntryAndSpan(size_t)
abort() was called at PC 0x400f3a6b on core 0
ELF file SHA256: 0000000000000000
Backtrace: 0x4008c724:0x3ffbc150 0x4008c99d:0x3ffbc170 0x400f3a6b:0x3ffbc190 0x4015c9fa:0x3ffbc1c0 0x4015d2e9:0x3ffbc210 0x4015d69e:0x3ffbc290 0x4015dc7f:0x3ffbc2e0 0x4015b5b1:0x3ffbc350 0x4015ae2d:0x3ffbc3b0 0x4015aedf:0x3ffbc3d0 0x4015af2a:0x3ffbc3f0 0x400d78a3:0x3ffbc410 0x400d8a31:0x3ffbc430 0x401540ab:0x3ffbc460 0x4008d9a2:0x3ffbc480
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
The same message occurs with various modules of the same type.
I have reverted back to earlier versions of software and the same message occurs.
I have plugged a module into what Amazon refer to as a Burner Shield and the board works fine - no error messages. In order to do this however I have had to cut out the PIR handling code - so in the hardware configuration it isn't doing what I want, so I need it working in the original board.
I made up a little programming board myself. The only connections are 5v, GND, TX, RX. This module worked perfectly ok until now.
The only thing that I can think of is that I used a different library when setting up Arduino IDE or that Windows 11 doesn't work the same.
Any help would be appreciated.
ps I have trimmed the software right down to use minimal code but it still repeats the same message
You can open an issue to notify developers that there is some incompatibility with Windows 11.
Can you not load even a simple blink sketch ?
If you want to raise an issue, do so with Espressif, they produce and support the ESP32 Core for the Arduino IDE;
