Code is quite long and loads multiple files and a quite big library. Its the named example sketch, so I thougt I don't need to post it. It is in esp32 addtions. I am using Version 1.0.3.
I am a bit further and tracked the port assignment down to file app_httpd.cpp in function void startCameraServer().
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
httpd_uri_t index_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = index_handler,
.user_ctx = NULL
httpd_uri_t status_uri = {
.uri = "/status",
.method = HTTP_GET,
.handler = status_handler,
.user_ctx = NULL
httpd_uri_t cmd_uri = {
.uri = "/control",
.method = HTTP_GET,
.handler = cmd_handler,
.user_ctx = NULL
httpd_uri_t capture_uri = {
.uri = "/capture",
.method = HTTP_GET,
.handler = capture_handler,
.user_ctx = NULL
httpd_uri_t stream_uri = {
.uri = "/Test",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
ra_filter_init(&ra_filter, 20);
mtmn_config.type = FAST;
mtmn_config.min_face = 80;
mtmn_config.pyramid = 0.707;
mtmn_config.pyramid_times = 4;
mtmn_config.p_threshold.score = 0.6;
mtmn_config.p_threshold.nms = 0.7;
mtmn_config.p_threshold.candidate_number = 20;
mtmn_config.r_threshold.score = 0.7;
mtmn_config.r_threshold.nms = 0.7;
mtmn_config.r_threshold.candidate_number = 10;
mtmn_config.o_threshold.score = 0.7;
mtmn_config.o_threshold.nms = 0.7;
mtmn_config.o_threshold.candidate_number = 1;
face_id_init(&id_list, FACE_ID_SAVE_NUMBER, ENROLL_CONFIRM_TIMES);
config.server_port = 8080;
Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&camera_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(camera_httpd, &index_uri);
httpd_register_uri_handler(camera_httpd, &cmd_uri);
httpd_register_uri_handler(camera_httpd, &status_uri);
httpd_register_uri_handler(camera_httpd, &capture_uri);
// httpd_register_uri_handler(stream_httpd, &stream_uri);
config.server_port = 80;
config.ctrl_port += 1;
Serial.printf("Starting stream server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
I was able to change the path here in .uri line:
.uri = "/Test",
.method = HTTP_GET,
.user_ctx = NULL
Also I changed the server ports for the default server to 8080 and the stream server to 80 by setting config.server_port before calling httpd_start. So this seems to work for me at first glance, but there is one thing I don't understand. Why does it not work to just register the stream_uri hanlder within the first server instance? Why do I need a specific server instance with additional port?
This here does not work. Access to /Test gives me HTTP 404 URI does not exist.
(registered &stream_uri at last)
Thanks a lot
