So I created a PCB that was based on ESP32-CAM actually but something seems to be wrong that when I use the camera, somehow the WiFi transmission or antenna doesn't work. So I decided to use serial communication to transmit the frame buffer across UART to another ESP module and host a server there.
However, I'm really bad at going about changing between data types especially when pointers are involved. From what I've known so fb is a uint_8t
which is similar to byte. So how do I transmit this using Serial.write()
properly and receive the same thing in another ESP board and switch it back to uint_8t
so that I can use it to host a webserver.
In this program that I'm doing the serial monitor just went crazy probably bcoz it can't turn the characters into ASCII, so I really have no idea whats going on or what im doing.
Transmiter code:
#include "WiFi.h"
#include "esp_camera.h"
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
bool initCamera(){
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_SVGA; //resolution
config.jpeg_quality = 12;
config.fb_count = 1;
config.fb_location = CAMERA_FB_IN_DRAM;
esp_err_t result = esp_camera_init(&config);
return true;
if(!initCamera()){
Serial.printf("Failed to Initialize OV2640 Camera");
return;
camera_fb_t * fb = NULL;
fb = esp_camera_fb_get();
Serial.write((unsigned char*)fb->buf,fb->len);
Serial.write('\n');
esp_camera_fb_return(fb);
delay(10);
Receiver code:
#include "ESP8266WiFi.h"
#include "ESPAsyncWebServer.h"
const char* ssid = "myssid";
const char* password = "mypass";
AsyncWebServer server(80);
uint8_t fb;
size_t fblen;
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
server.on("/picture", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send_P(200, "image/jpeg", (const char *)fb, sizeof(fb));
server.begin();
void loop(){
int count = 0;
while(Serial.available()>0){
byte message = Serial.read();
if(message == 0x0A)
fb[count] = uint8_t*(message);
count++;
