Hi everyone,
I'm working on a drone project where I want my ESP32-CAM to:
- Provide a live stream.
- Record video when the drone is armed and stop recording when disarmed. The video should be saved as an AVI file on the microSD card inserted into the ESP32-CAM.
To achieve this, I’ve been using the ESP32-CAM_MJPEG2SD project from GitHub and followed the instructions from this video tutorial.
Problem with Latest Code Version:
When I use the latest code version from the GitHub repository, the upload works fine, but when I try to access the stream via the IP address, I get the following error message:
Startup Failure: Insufficient PSRAM for app: 2.0MB
Workaround with Older Versions:
I tried installing earlier versions of the code and the board, because I saw in the video that the features that I want work:
ESP32-CAM_MJPEG2SD version 8.4a from GitHub.
ESP32 board version 2.0.5 in the Arduino IDE.
With this setup, the system works but with some issues. The main problem is that the ESP32-CAM access point becomes unstable, and I can't stay connected for long. Despite this, I managed to stream video and save recorded AVI files on the SD card.
Hardware Setup:
I’m using the ESP32-CAM module with the ESP32-CAM-MB adapter, connected to my flight controller (SpeedyBee F405 V4) as follows:
5V (SpeedyBee F405 V4) → 5V (ESP32-CAM module)
G (SpeedyBee F405 V4) → GND (ESP32-CAM module)
R3 (SpeedyBee F405 V4) → U0T (ESP32-CAM module)
T3 (SpeedyBee F405 V4) → U0R (ESP32-CAM module)
My Questions:
- Can I achieve stable performance with the older version of the GitHub code and the ESP32 board version 2.0.5?
- Is there any way to fix the "Insufficient PSRAM" issue with the latest code version?
- How can I make the ESP32-CAM's access point more stable for longer connections?
Any suggestions or insights would be greatly appreciated!
