Hello,
Here is the error message below. Any ideas?
fork/exec cmd.com: The system cannot find the file specified.
Error compiling for board AI Thinker ESP32-CAM.
This is the first time compiling with this board. Here are the selected board settings (see attachments).
Here is the full log:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), DIO, Huge APP (3MB No OTA/1MB SPIFFS), 40MHz, Info"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Acer\Documents\ArduinoData\packages -hardware D:\Matt\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Acer\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\Matt\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=dio,PartitionScheme=huge_app,FlashFreq=40,DebugLevel=info -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\Acer\AppData\Local\Temp\arduino_build_676604 -warnings=default -build-cache C:\Users\Acer\AppData\Local\Temp\arduino_cache_120810 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.3.0 -verbose D:\Matt\Arduino\CameraWebServer\CameraWebServer.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Acer\Documents\ArduinoData\packages -hardware D:\Matt\Arduino\hardware -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Acer\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries D:\Matt\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=dio,PartitionScheme=huge_app,FlashFreq=40,DebugLevel=info -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\Acer\AppData\Local\Temp\arduino_build_676604 -warnings=default -build-cache C:\Users\Acer\AppData\Local\Temp\arduino_cache_120810 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\Acer\Documents\ArduinoData\packages\esp32\tools\esptool_py\3.3.0 -verbose D:\Matt\Arduino\CameraWebServer\CameraWebServer.ino
Using board 'esp32cam' from platform in folder: C:\Users\Acer\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.4
Using core 'esp32' from platform in folder: C:\Users\Acer\Documents\ArduinoData\packages\esp32\hardware\esp32\2.0.4
cmd /c if exist "D:\\Matt\\Arduino\\CameraWebServer\\partitions.csv" COPY /y "D:\\Matt\\Arduino\\CameraWebServer\\partitions.csv" "C:\\Users\\Acer\\AppData\\Local\\Temp\\arduino_build_676604\\partitions.csv"
Thanks in advance.
