Esp32-cam-mb connection with multimeter
I have to check the current (Ampere) of my esp32 cam, for now after various tests I have arrived at these procedures:
  • I separated the 2 modules (MB and camera)
  • I connected microusb to the MB module
  • i connected pins 5V and GND (from MB Module to Camera module)
(with MB I mean the module with the micro USB without camera)
AND ALL WORKS (NOT MULTIMETER :frowning: )
BUT
I tried to put the multimeter between the others GND and 3V or GND and 5V but without success, I don't know which pin to put it among for measuring Ampere.
thanks for your future reply :slight_smile:
Try a Google search for the 'ESP32CAM Schematic'.
The schematic will make clear which pin is supplying input power to the regulator (AMS1117/3.3V) on the ESP32CAM board.
To measure current the multimeter needs to be on a suitable current range and in series with the pin supplying input power.
If you put the multimeter on a current range and put it across GND and 5V or GND and 3V3, you could damage the ESP32CAM, the power supply, and\or blow the fuse in your multimeter.
I noticed, it went out with a spark. :frowning:
now i solved and thank you
