ESP32 cam module problem
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include "esp_camera.h"
// WiFi credentials
const char* ssid = "realme 3 Pro";
const char* password = "87654321";
// Server configuration
const char* server_ip = "192.168.105.253";
const int server_port = 65000;
// Camera configuration
const int camera_port = 81;  // Default camera port
const char* camera_host = "esp32-cam";
// Camera pins
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
  pinMode(14, INPUT_PULLUP);
  // Connect to WiFi
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  // Camera setup
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_UXGA;
  config.jpeg_quality = 10;
  config.fb_count = 1;
  // Initialize camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
  Serial.println("Camera initialized");
  if(digitalRead(14)== HIGH){
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      return;
   // Connect to server
    WiFiClient client;
    if (!client.connect(server_ip, server_port)) {
      Serial.println("Not Connected to server");
      return;
   // Send image data
    client.write(fb->buf, fb->len);
    Serial.println("Image sent");
  // Cleanup
    esp_camera_fb_return(fb);
    client.stop();
  delay(300);
this is my code for esp32 cam module. whenever it receives a pulse from my other microcontroller, it should capture an image. but the loop is executing even if i dont connect it to other microcontroller. i can see the loop executing from my serial monitor output
Connected to WiFi
Camera initialized
found the problem. serial begin should come after pin mode.
you got pinMode INPUT_PULLUP on this pin..
maybe you should be looking for LOW??
good luck.. ~q
