This is the code I'm using, Everytime I try to program it I get a serial data not received error. It was working after my last post when I got the gnd hooked up right I let it sit a few days now i get this serial data not received error.
Leave gp0 connected to ground and after software starts communication press the reset button ( sometimes it does not work, so retry ),
Is ftdi set to 3.3V?
Press the boot button when the connecting message appears. You can also press it before then. NOTE, it is finicky, just because it doesn't work once does NOT mean it will not work on the 10th try.
esp32 is powered at 3.3V so your ftdi output logic level shoud be compatible, if you have a jumper ( on the ftdi board ) that sets the logic level voltage set it at 3.3V
