I've been struggling for quite some time with a very strange problem. My ESP32-CAMs (bought from 3 different suppliers) only work momentarily when the GND jumper is being pulled out.
I can upload a wiring schematic, but I don't think that's the problem; The "est" that you see is the beginning of the ESP32-CAM bootup, so I'm pretty sure the wiring's not the problem. The issue persists when I wire it directly to the FTDI programmer too. I've tested the programmer with a multimeter and it's reading the 5 volts that I'm expecting. This has been very frustrating and any help would be greatly appreciated.
I'm not entirely sure what you mean. I should clarify, I got the same behavior using a USB cable. A serial echo on my FTDI programmer (i.e. shorting TXD and RXD) works fine, but I can't power the board long enough to upload the code so I can run a serial echo.
