Hello everyone, good work, I am thinking of installing the system you see in the picture with esp32-cam.
1- Customization options
WIFI - BT - WIRED (ETHERNET) OR USB??
Remote access - local access (cable)
I would like to enable each of the above customization options at the same time or only one or both of them depending on personal preference.
2- I aim to use a multi-channel, long-lasting camera system - there are USB cable to ethernet converters available. If it supports the system in the image and what I say, I would be happy if you share the open source codes related to it (I will perform an installation from scratch, please show the order of writing the codes in an understandable way.)
3- I assume there is an open source code related to this, and if there is not, I think someone will definitely help as a lesson.
4- I think ESP32-CAM Hardware can handle all these features. Am I right? I'm waiting for your answers, thank you.
ESP32 supports ETH Connection, USB can also be used instead of ETH and by the way, there are USB to ETH converter devices. Will POE and NVR devices recognize this converter?
I don't fully understand your purpose. Do you want to help me or argue? Which devices were used and how much did they cost? If you would like to help, I would appreciate it if you could sort this out. Thanks...
