ESP32 cam programming error
Hi, Im trying to setup a few ESP32 cameras, and 2 worked fine, but the 3rd one keep giving me an error :frowning:
"Skissen bruker 1498113 bytes (47%) av program lagrings minnet. Maks er 3145728 bytes
Globale variabler bruker 70800 bytes (21%) av dynamisk minne, som etterlater 256880 bytes til lokale variabler. Maks er 327680 bytes.
esptool.py v4.5.1
Serial port COM6
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
den valgte serieporten For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
eksisterer ikke, eller kortet ditt er ikke tilkoblet
This is the info Im getting from the serial monitor, so as far I can see, the board is connected? Using a ESP32-CAM bord, with a ESP32-CAM-MB USB board for programming. Have tried 3 different USB boards, same error :frowning:
⸮B⸮⸮>#⸮cV⸮⸮aD⸮⸮⸮?⸮⸮Bc⸮ca⸮⸮⸮⸮ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:4
load:0x3fff0034,len:6968
load:0x40078000,len:13072
ho 0 tail 12 room 4
load:0x40080400,len:3896
entry 0x40080688
e[0;32mI (31) boot: ESP-IDF v4.1-dirty 2nd stage bootloadere[0m
e[0;32mI (31) boot: compile time 16:15:01e[0m
e[0;32mI (31) boot: chip revision: 3e[0m
e[0;32mI (34) boot_comm: chip revision: 3, min. bootloader chip revision: 0e[0m
e[0;32mI (41) boot.esp32: SPI Speed : 40MHze[0m
e[0;32mI (46) boot.esp32: SPI Mode : DIOe[0m
e[0;32mI (51) boot.esp32: SPI Flash Size : 4MBe[0m
e[0;32mI (55) boot: Enabling RNG early entropy source...e[0m
e[0;32mI (60) boot: Partition Table:e[0m
e[0;32mI (64) boot: ## Label Usage Type ST Offset Lengthe[0m
e[0;32mI (71) boot: 0 nvs WiFi data 01 02 00009000 00005000e[0m
e[0;32mI (79) boot: 1 otadata OTA data 01 00 0000e000 00002000e[0m
e[0;32mI (86) boot: 2 app0 OTA app 00 10 00010000 00300000e[0m
e[0;32mI (94) boot: 3 spiffs Unknown data 01 82 00310000 000f0000e[0m
e[0;32mI (101) boot: End of partition tablee[0m
e[0;32mI (106) boot_comm: chip revision: 3, min. application chip revision: 0e[0m
e[0;32mI (113) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1d2048 (1908808) mape[0m
e[0;32mI (849) esp_image: segment 1: paddr=0x001e2070 vaddr=0x3ffbdb60 size=0x04d3c ( 19772) loade[0m
e[0;32mI (857) esp_image: segment 2: paddr=0x001e6db4 vaddr=0x40080000 size=0x00400 ( 1024) loade[0m
e[0;32mI (858) esp_image: segment 3: paddr=0x001e71bc vaddr=0x40080400 size=0x08e54 ( 36436) loade[0m
e[0;32mI (880) esp_image: segment 4: paddr=0x001f0018 vaddr=0x400d0018 size=0x9df74 (647028) mape[0m
e[0;32mI (1127) esp_image: segment 5: paddr=0x0028df94 vaddr=0x40089254 size=0x0b6a0 ( 46752) loade[0m
e[0;32mI (1159) boot: Loaded app from partition at offset 0x10000e[0m
e[0;32mI (1159) boot: Disabling RNG early entropy source...e[0m
SD Size: 121MB OK
PSRAM OK
ESP32-CAM-MB
Anyone have any idea how to fix this?
If you have 3 identical ESP32CAMs, from the same source, and you are programming them in the same way and two respond but the third does not, then its most likely the third is broken.
bought from 2 different sellers, but look the same?
Did the one on the left of the bottom picture fail to program ?
yes, the one with HW on it didnt want to program :frowning:
Any suggestions? :slight_smile:
The obvious one, did you try and program the failing one, without the SD card inserted ?
hehe yes :slight_smile:
