Hello everyboby,
I'm new on this Forum I'm also new in a lot of subject regarding ARDUINO IDE, ESP32 CAM and C language so please, be friendly with me even if my post seems to be confused or simple many thanks by advance for that!
I'm programming a CCTV installation based on ESP32 CAM. I used Eloquent vision libraries, the web server is esp_http_server and everything is almost working:
- video streaming (mjpeg) OK
- pan/tilt (servo) OK
- image capture (sd card) OK
- directory image list (via browser) OK
- delete image (via browser) OK
But I'm facing a problem to get jpg file from sd card and sending it to the browser.
I tried a lot a formulation but no one is working Here after is one of them this is the method handling the view function:
static esp_err_t action_handler(httpd_req_t *req){
// result http header manipulation
esp_err_t res = ESP_OK;
uint8_t * fb;
size_t fb_len;
// Buffer http request
char* buf;
size_t buf_len;
char variable[32] = {0,};
buf_len = httpd_req_get_url_query_len(req) + 1;
if (buf_len > 1) {
buf = (char*)malloc(buf_len);
if(!buf){
httpd_resp_send_500(req);
return ESP_FAIL;
if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
if (httpd_query_key_value(buf, "get", variable, sizeof(variable)) == ESP_OK) {
res = httpd_resp_set_type(req, "image/jpeg");
if (res == ESP_OK)
res = httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=image.jpg");
if (res == ESP_OK) {
File image = SD_MMC.open("/cctv/capture" + String(variable),FILE_READ);
if (!image) {
Serial.println("Opening file to read failed");
return httpd_resp_send_500(req);
fb_len = image.size();
Serial.println("Before read");
Serial.println(fb_len);
image.read((uint8_t *)fb, fb_len);
Serial.println("Afters read");
Serial.println(size_t(fb));
image.close();
free(buf);
return httpd_resp_send(req, (const char *)fb, fb_len);
else {
free(buf);
return ESP_FAIL;
I get the right size for file size (fb_len), but buffer size (size_t(fb)) is zero!
If any one can help me ...
Cordially
