Bonjour
Je ne comprends pourquoi ce ino fonctionne et un moment apres pas !!!
Log Good
15:57:31.707 ->
15:57:31.707 -> rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
15:57:31.707 -> configsip: 0, SPIWP:0xee
15:57:31.707 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
15:57:31.707 -> mode:DIO, clock div:1
15:57:31.707 -> load:0x3fff0018,len:4
15:57:31.707 -> load:0x3fff001c,len:1216
15:57:31.707 -> ho 0 tail 12 room 4
15:57:31.707 -> load:0x40078000,len:9720
15:57:31.741 -> ho 0 tail 12 room 4
15:57:31.741 -> load:0x40080400,len:6352
15:57:31.741 -> entry 0x400806b8
15:57:33.501 ->
15:57:33.501 -> Booting...
15:57:33.571 -> SPIFFS ok
15:57:33.571 -> Delete picture.jpg
15:57:33.672 -> SPIFFS.dir passed
15:57:33.672 -> Connecting to AP.
15:57:33.878 -> WiFi connected.
15:57:33.878 -> IP address:
15:57:33.912 -> 192.168.1.54
15:57:33.912 ->
15:57:33.912 -> OTA start Sillage
15:57:33.912 -> ArduinoOTA.setHostname Sillage-94b088
15:57:33.912 -> OTA Initialized
15:57:34.724 -> Taking a picture ...
15:57:34.894 -> Picture file name: /picture.jpg
15:57:34.894 -> Size of image:148648
15:57:34.894 -> Shape->width:1600height:1200
15:57:36.015 -> The picture has been saved in /picture.jpg - Size: 148608 bytes
15:57:36.015 -> Sending email...
15:57:36.015 -> Connecting to SMTP server...
15:57:42.043 -> Identification...
15:57:42.145 -> Authentication...
15:57:42.178 -> Sign in...
15:57:42.553 -> Sending Email header...
15:57:42.587 -> Sending Email body...
15:57:42.857 -> Sending attachments...
15:57:42.857 -> /picture.jpg
15:58:13.612 -> Finalize...
15:58:15.004 -> Finished
15:58:15.004 -> Email sent successfully
15:58:15.004 -> ----------------
15:58:15.004 -> Entering deep sleep mode
15:58:15.004 -> GPIO_NUM_13 = 1
15:58:15.004 -> Wakeup caused by external signal using RTC_IO
15:58:30.028 -> delay(10000)
Log Bad
15:56:06.384 ->
15:56:06.384 -> rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
15:56:06.384 -> configsip: 0, SPIWP:0xee
15:56:06.384 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
15:56:06.384 -> mode:DIO, clock div:1
15:56:06.384 -> load:0x3fff0018,len:4
15:56:06.384 -> load:0x3fff001c,len:1216
15:56:06.384 -> ho 0 tail 12 room 4
15:56:06.384 -> load:0x40078000,len:9720
15:56:06.418 -> load:0x40080400,len:6352
15:56:06.418 -> entry 0x400806b8
15:56:08.160 ->
15:56:08.160 -> Booting...
15:56:08.228 -> SPIFFS ok
15:56:08.262 -> Delete picture.jpg
15:56:08.329 -> SPIFFS.dir passed
15:56:08.329 -> Connecting to AP..
15:56:08.773 -> WiFi connected.
15:56:08.773 -> IP address:
15:56:08.773 -> 192.168.1.54
15:56:08.773 ->
15:56:08.773 -> OTA start Sillage
15:56:08.773 -> ArduinoOTA.setHostname Sillage-94b088
15:56:08.773 -> OTA Initialized
15:56:09.587 -> Taking a picture ...
15:56:09.964 -> Picture file name: /picture.jpg
15:56:09.964 -> Size of image:326938
15:56:09.964 -> Shape->width:1600height:1200
15:56:10.855 -> The picture has been saved in /picture.jpg - Size: 0 bytes
15:56:10.855 -> Sending email...
15:56:10.855 -> Connecting to SMTP server...
15:56:16.964 -> Identification...
15:56:16.964 -> Authentication...
15:56:16.998 -> Sign in...
15:56:17.477 -> Sending Email header...
15:56:17.782 -> Sending Email body...
15:56:18.023 -> Sending attachments...
15:56:18.023 -> /picture.jpg
15:56:18.023 -> Finalize...
15:56:18.704 -> Finished
15:56:18.704 -> Email sent successfully
15:56:18.704 -> ----------------
15:56:18.704 -> Entering deep sleep mode
15:56:18.704 -> GPIO_NUM_13 = 0
15:56:18.704 -> Wakeup caused by external signal using RTC_IO
15:56:33.687 -> delay(10000)
Size of image:148648 <> Size of image:326938
Pouquoi ???
Merci
extrait de code
#define CAMERA_MODEL_AI_THINKER
#define FILE_PHOTO "/picture.jpg"
bool checkPhoto( fs::FS & fs ) {
File f_pic = fs.open( FILE_PHOTO );
unsigned int pic_sz = f_pic.size();
return ( pic_sz > 100 );
/*********************** SPIFFS **********************/
if (!SPIFFS.begin())
Serial.println("Erreur SPIFFS...");
return;
Serial.println("SPIFFS ok ");
//---------------------------------------------------- delete /picture.jpg
if (SPIFFS.remove("/picture.jpg")){
Serial.println("Delete picture.jpg ");
Serial.println("Delete picture.jpg Erreur");
File SPIFF_root = SPIFFS.open("/", "r");
File SPIFF_file = SPIFF_root.openNextFile();
Serial.println("SPIFFS.dir passed ");
while (SPIFF_file) {
Serial.print("FILE: ");
Serial.print(SPIFF_file.name());
Serial.print(" - Size: ");
Serial.print(SPIFF_file.size());
Serial.println(" bytes");
//init with high specs to pre-allocate larger buffers
if (psramFound())
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
} else
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
//---------------------------------------------------- camera capture to SPIFFS
Serial.println("Taking a picture ...");
camera_fb_t * fb = NULL;
//obtain camera frame buffer
fb = esp_camera_fb_get();
if (!fb)
Serial.println("Camera capture failed");
Serial.println("Exiting now");
while (1); //wait here as something is not right
Serial.printf("Picture file name: %s\n", FILE_PHOTO);
Serial.print("Size of image:");
Serial.println(fb->len);
Serial.print("Shape->width:");
Serial.print(fb->width);
Serial.print("height:");
Serial.println(fb->height);
//create new file
File file = SPIFFS.open(FILE_PHOTO, FILE_WRITE);
if (!file)
Serial.println("Failed to create file");
file.write(fb->buf, fb->len); // payload (image), payload length
Serial.print("The picture has been saved in ");
Serial.print(FILE_PHOTO);
Serial.print(file.size());
file.close();
//return camera frame buffer
esp_camera_fb_return(fb);
//Set the storage types to read the attach files (SPIFF is default)
smtpData.addAttachFile("/picture.jpg", "image/jpeg");
// Set the storage type to attach files in your email (SPIFFS)
smtpData.setFileStorageType(MailClientStorageType::SPIFFS);
