ESP32-CAM
Ich habe unten angehangenen Code auf den ESP32 gespielt.
Soweit läuft auch alles.
Allerdings muss ich nach spannungsreset immer den kleinen taster auf dem ESP32 drücken, damit die Camera wieder läuft.
Woran könnte das liegen?
 Rui Santos
 Complete project details at https://RandomNerdTutorials.com/esp32-cam-video-streaming-web-server-camera-home-assistant/
 IMPORTANT!!!
  - Select Board "AI Thinker ESP32-CAM"
  - GPIO 0 must be connected to GND to upload a sketch
  - After connecting GPIO 0 to GND, press the ESP32-CAM on-board RESET button to put your board in flashing mode
 Permission is hereby granted, free of charge, to any person obtaining a copy
 of this software and associated documentation files.
 The above copyright notice and this permission notice shall be included in all
 copies or substantial portions of the Software.
#include "esp_camera.h"
#include <WiFi.h>
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "soc/soc.h" //disable brownout problems
#include "soc/rtc_cntl_reg.h"  //disable brownout problems
#include "esp_http_server.h"
//Replace with your network credentials
const char* ssid = "xxxxxxxxxxxxxxx";
const char* password = "xxxxxxxxxxxxxxxxxxxxx";
#define PART_BOUNDARY "123456789000000000000987654321"
// This project was tested with the AI Thinker Model, M5STACK PSRAM Model and M5STACK WITHOUT PSRAM
#define CAMERA_MODEL_AI_THINKER
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WITHOUT_PSRAM
// Not tested with this model
//#define CAMERA_MODEL_WROVER_KIT
#if defined(CAMERA_MODEL_WROVER_KIT)
 #define PWDN_GPIO_NUM    -1
 #define RESET_GPIO_NUM   -1
 #define XCLK_GPIO_NUM    21
 #define SIOD_GPIO_NUM    26
 #define SIOC_GPIO_NUM    27
 #define Y9_GPIO_NUM      35
 #define Y8_GPIO_NUM      34
 #define Y7_GPIO_NUM      39
 #define Y6_GPIO_NUM      36
 #define Y5_GPIO_NUM      19
 #define Y4_GPIO_NUM      18
 #define Y3_GPIO_NUM       5
 #define Y2_GPIO_NUM       4
 #define VSYNC_GPIO_NUM   25
 #define HREF_GPIO_NUM    23
 #define PCLK_GPIO_NUM    22
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
 #define RESET_GPIO_NUM    15
 #define XCLK_GPIO_NUM     27
 #define SIOD_GPIO_NUM     25
 #define SIOC_GPIO_NUM     23
 #define Y9_GPIO_NUM       19
 #define Y8_GPIO_NUM       36
 #define Y7_GPIO_NUM       18
 #define Y6_GPIO_NUM       39
 #define Y5_GPIO_NUM        5
 #define Y4_GPIO_NUM       34
 #define Y3_GPIO_NUM       35
 #define Y2_GPIO_NUM       32
 #define VSYNC_GPIO_NUM    22
 #define HREF_GPIO_NUM     26
 #define PCLK_GPIO_NUM     21
#elif defined(CAMERA_MODEL_M5STACK_WITHOUT_PSRAM)
 #define Y2_GPIO_NUM       17
#elif defined(CAMERA_MODEL_AI_THINKER)
 #define PWDN_GPIO_NUM     32
 #define XCLK_GPIO_NUM      0
 #define Y5_GPIO_NUM       21
 #define Y4_GPIO_NUM       19
 #define Y3_GPIO_NUM       18
 #define Y2_GPIO_NUM        5
#else
 #error "Camera model not selected"
#endif
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t stream_httpd = NULL;
static esp_err_t stream_handler(httpd_req_t *req){
 camera_fb_t * fb = NULL;
 esp_err_t res = ESP_OK;
 size_t _jpg_buf_len = 0;
 uint8_t * _jpg_buf = NULL;
 char * part_buf[64];
 res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
 if(res != ESP_OK){
   return res;
 while(true){
   fb = esp_camera_fb_get();
   if (!fb) {
     Serial.println("Camera capture failed");
     res = ESP_FAIL;
     if(fb->width > 400){
       if(fb->format != PIXFORMAT_JPEG){
         bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
         esp_camera_fb_return(fb);
         fb = NULL;
         if(!jpeg_converted){
           Serial.println("JPEG compression failed");
           res = ESP_FAIL;
         _jpg_buf_len = fb->len;
         _jpg_buf = fb->buf;
   if(res == ESP_OK){
     size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
     res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
   if(res == ESP_OK){
     res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
   if(res == ESP_OK){
     res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
   if(fb){
     fb = NULL;
     _jpg_buf = NULL;
   } else if(_jpg_buf){
     free(_jpg_buf);
     _jpg_buf = NULL;
   if(res != ESP_OK){
   //Serial.printf("MJPG: %uB\n",(uint32_t)(_jpg_buf_len));
 return res;
void startCameraServer(){
 httpd_config_t config = HTTPD_DEFAULT_CONFIG();
 config.server_port = 80;
 httpd_uri_t index_uri = {
   .uri       = "/",
   .method    = HTTP_GET,
   .handler   = stream_handler,
   .user_ctx  = NULL
 //Serial.printf("Starting web server on port: '%d'\n", config.server_port);
 if (httpd_start(&stream_httpd, &config) == ESP_OK) {
   httpd_register_uri_handler(stream_httpd, &index_uri);
 WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
 Serial.setDebugOutput(false);
 camera_config_t config;
 config.ledc_channel = LEDC_CHANNEL_0;
 config.ledc_timer = LEDC_TIMER_0;
 config.pin_d0 = Y2_GPIO_NUM;
 config.pin_d1 = Y3_GPIO_NUM;
 config.pin_d2 = Y4_GPIO_NUM;
 config.pin_d3 = Y5_GPIO_NUM;
 config.pin_d4 = Y6_GPIO_NUM;
 config.pin_d5 = Y7_GPIO_NUM;
 config.pin_d6 = Y8_GPIO_NUM;
 config.pin_d7 = Y9_GPIO_NUM;
 config.pin_xclk = XCLK_GPIO_NUM;
 config.pin_pclk = PCLK_GPIO_NUM;
 config.pin_vsync = VSYNC_GPIO_NUM;
 config.pin_href = HREF_GPIO_NUM;
 config.pin_sscb_sda = SIOD_GPIO_NUM;
 config.pin_sscb_scl = SIOC_GPIO_NUM;
 config.pin_pwdn = PWDN_GPIO_NUM;
 config.pin_reset = RESET_GPIO_NUM;
 config.xclk_freq_hz = 20000000;
 config.pixel_format = PIXFORMAT_JPEG;
 if(psramFound()){
   config.frame_size = FRAMESIZE_UXGA;
   config.jpeg_quality = 10;
   config.fb_count = 2;
   config.frame_size = FRAMESIZE_SVGA;
   config.jpeg_quality = 12;
   config.fb_count = 1;
 // Camera init
 esp_err_t err = esp_camera_init(&config);
 if (err != ESP_OK) {
   Serial.printf("Camera init failed with error 0x%x", err);
   return;
 // Wi-Fi connection
 WiFi.begin(ssid, password);
   Serial.print(".");
 Serial.println("");
 Serial.println("WiFi connected");
 Serial.print("Camera Stream Ready! Go to: http://");
 Serial.print(WiFi.localIP());
 // Start streaming web server
 startCameraServer();
 delay(1);
Setze Deinen Code bitte in Codetags (</>-Button oben links im Forumseditor oder [code] davor und [/code] dahinter ohne *).
Dann ist er auch auf mobilen Geräten besser lesbar.
Das kannst Du auch noch nachträglich ändern.
Gruß Tommy
