Esp32 camera not connecting to my server
i am using esp32 ai thinker to capture a photo and send it to the flask server . I am providing my computer server address but still not working.
here is the code
#include <WiFi.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
//======================================== CAMERA_MODEL_AI_THINKER GPIO.
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
// LED Flash PIN (GPIO 4)
#define FLASH_LED_PIN 4
//======================================== Insert your network credentials.
const char* ssid = "realme 6";
const char* password = "{redacted}";
//======================================== Variables for Timer/Millis.
unsigned long previousMillis = 0;
const int Interval = 20000; //--> Photo capture every 20 seconds.
// Server Address or Server IP.
String serverName = "192.168.X.X";  //--> Change with your server computer's IP address or your Domain name.
IPAddress server(192, 168, X, X);
// The file path "upload_img.php" on the server folder.
String serverPath = "http://127.0.0.1:5000";
// Server Port.
const int serverPort = 80;
// Variable to set capture photo with LED Flash.
// Set to "false", then the Flash LED will not light up when capturing a photo.
// Set to "true", then the Flash LED lights up when capturing a photo.
bool LED_Flash_ON = true;
// Initialize WiFiClient.
WiFiClient client;
//________________________________________________________________________________ sendPhotoToServer()
void sendPhotoToServer() {
  String AllData;
  String DataBody;
  Serial.println("-----------");
  //---------------------------------------- Pre capture for accurate timing.
  Serial.println("Taking a photo...");
  if (LED_Flash_ON == true) {
    digitalWrite(FLASH_LED_PIN, HIGH);
  for (int i = 0; i <= 3; i++) {
    camera_fb_t * fb = NULL;
    fb = esp_camera_fb_get();
     if(!fb) {
        Serial.println("Camera capture failed");
        Serial.println("Restarting the ESP32 CAM.");
        ESP.restart();
        return;
    esp_camera_fb_return(fb);
    delay(200);
  if(!fb) {
    ESP.restart();
    return;
  if (LED_Flash_ON == true) digitalWrite(FLASH_LED_PIN, LOW);
  Serial.println("Taking a photo was successful.");
  Serial.println("Connecting to server: " + serverName);
  if (client.connect(server, serverPort)) {
    Serial.println("Connection successful!");
    String post_data = "--dataMarker\r\nContent-Disposition: form-data; name=\"imageFile\"; filename=\"ESP32CAMCap.jpg\"\r\nContent-Type: image/jpeg\r\n\r\n";
    String head =  post_data;
    String boundary = "\r\n--dataMarker--\r\n";
    uint32_t imageLen = fb->len;
    uint32_t dataLen = head.length() + boundary.length();
    uint32_t totalLen = imageLen + dataLen;
    client.println("POST " + serverPath + " HTTP/1.1");
    client.println("Host: " + serverName);
    client.println("Content-Length: " + String(totalLen));
    client.println("Content-Type: multipart/form-data; boundary=dataMarker");
    client.println();
    client.print(head);
    uint8_t *fbBuf = fb->buf;
    size_t fbLen = fb->len;
    for (size_t n=0; n<fbLen; n=n+1024) {
      if (n+1024 < fbLen) {
        client.write(fbBuf, 1024);
        fbBuf += 1024;
      else if (fbLen%1024>0) {
        size_t remainder = fbLen%1024;
        client.write(fbBuf, remainder);
    client.print(boundary);
    int timoutTimer = 10000;
    long startTimer = millis();
    boolean state = false;
    Serial.println("Response : ");
    while ((startTimer + timoutTimer) > millis()) {
      Serial.print(".");
      delay(200);
      // Skip HTTP headers
      while (client.available()) {
        char c = client.read();
        if (c == '\n') {
          if (AllData.length()==0) { state=true; }
          AllData = "";
        else if (c != '\r') { AllData += String(c); }
        if (state==true) { DataBody += String(c); }
      if (DataBody.length()>0) { break; }
    client.stop();
    Serial.println(DataBody);
  else {
    client.stop();
    DataBody = "Connection to " + serverName +  " failed.";
//________________________________________________________________________________ VOID SETUP()
  // Disable brownout detector.
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  pinMode(FLASH_LED_PIN, OUTPUT);
  // Setting the ESP32 WiFi to station mode.
  WiFi.mode(WIFI_STA);
  //---------------------------------------- The process of connecting ESP32 CAM with WiFi Hotspot / WiFi Router.
  Serial.print("Connecting to : ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  // The process timeout of connecting ESP32 CAM with WiFi Hotspot / WiFi Router is 20 seconds.
  // If within 20 seconds the ESP32 CAM has not been successfully connected to WiFi, the ESP32 CAM will restart.
  // I made this condition because on my ESP32-CAM, there are times when it seems like it can't connect to WiFi, so it needs to be restarted to be able to connect to WiFi.
  int connecting_process_timed_out = 20; //--> 20 = 20 seconds.
  connecting_process_timed_out = connecting_process_timed_out * 2;
    Serial.print(".");
    if(connecting_process_timed_out > 0) connecting_process_timed_out--;
    if(connecting_process_timed_out == 0) {
      Serial.print("Failed to connect to ");
      ESP.restart();
  Serial.print("Successfully connected to ");
  //Serial.print("ESP32-CAM IP Address: ");
  //Serial.println(WiFi.localIP());
  //---------------------------------------- Set the camera ESP32 CAM.
  Serial.print("Set the camera ESP32 CAM...");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // init with high specs to pre-allocate larger buffers
  if(psramFound()){
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 10;  //--> 0-63 lower number means higher quality
    config.fb_count = 2;
    config.frame_size = FRAMESIZE_SVGA;
    config.jpeg_quality = 8;  //--> 0-63 lower number means higher quality
    config.fb_count = 1;
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    ESP.restart();
  sensor_t * s = esp_camera_sensor_get();
  // Selectable camera resolution details :
  // -UXGA   = 1600 x 1200 pixels
  // -SXGA   = 1280 x 1024 pixels
  // -XGA    = 1024 x 768  pixels
  // -SVGA   = 800 x 600   pixels
  // -VGA    = 640 x 480   pixels
  // -CIF    = 352 x 288   pixels
  // -QVGA   = 320 x 240   pixels
  // -HQVGA  = 240 x 160   pixels
  // -QQVGA  = 160 x 120   pixels
  s->set_framesize(s, FRAMESIZE_SXGA); //--> UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  Serial.println("Set camera ESP32 CAM successfully.");
  Serial.print("ESP32-CAM captures and sends photos to the server every 20 seconds.");
//________________________________________________________________________________ VOID LOOP()
  //---------------------------------------- Timer/Millis to capture and send photos to server every 20 seconds (see Interval variable).
  if (currentMillis - previousMillis >= Interval) {
    sendPhotoToServer();
please help me !!
Did you look at the server logs to see why the connection is being refused?
In serial monitor it is showing that the camera is capturing the photos but after some time it is showing connection failed
Your topic has been moved to a more suitable location on the forum as it has nothing to do with Avrdude, stk500 or Bootloader issues.
I would be very grateful if you guide me how to solve this issue
It's an area that I have no (or limited) knowledge of.
But @Idahowalker asked you if there is something in the server logs that would indicate why your board can't connect.
Has the OP checked the router's logs to see why the connection is being refused?
how to check that?
I do not own the same server and router hardware that you do. I suggest that you read the manual for the server's OS on how to do the thing and read the manual for the router OS on how to do the thing.
So I have change the server path to my ip address and set my port to the same one provided in the flask server...
It was working fine
Suddenly again the same error is showing
This is what the terminal is showing
I am providing my ip4 address here which I am getting through ipconfig command
And what does the router and server logs indicate as to did the ESP32 camera try to connect or does the router have no log of an attempted connection? Is your router using MAC address access? I really do not have your router so I cannot help you with your router or server.
No i am using windows 11
When the server connected it was showing this in the serial monitor..
It happened when I changed my serverport to 5000 which was provided in the flask app
Please do not post passwords on the forum. Ditto for the image in post #15.
i have modified the code and it is working but i really cannot understand why this behaviour is happening
String serverName = "192.168.x.x";  //--> Change with your server computer's IP address or your Domain name.
String serverPath = "http://192.168.x.x/save/image";
// Server Port.
const int serverPort = y;
int x=client.connect(serverName.c_str(), serverPort);
  Serial.println(x);
  if (x)
  //if(WiFiMulti.run() == WL_CONNECTED)
it would be very helpful if someone explain me why this is happening and i can't assure it that it will not give me a error
