hi, I am kathy and a rookie in programming and arduino
I managed to flash a AI-Tinker-Cam with the sample code CameraWebServer and all worked fine and out of the box on first trial with a step-by-step-guide on YT
I can call the cam in browser by IP and make all the settings until the video pleases me
I even ws able to than include the stream in HomeAssistant ... so far so good
but every once in a while I need to cut the power of the board and then on next boot all setings made in the web-ui are gone and I am back to kind of default set
is there a way to modify the CameraWebServer sample sketch in a way that it saves the settings once made for next boot?
thx for reading and hopefully you can help me sort this out ... it is a little annoyning to adjust 4 cams every time manually
rgds
kathi
