ESP32 - Can't send UDP packets
I want to send a broadcast message from my computer and then reply it from the ESP32
I'm managing to receive the broadcast message but I can't send the reply message (I don't see it in the computer's wireshark)
I used a popular version from the Internet so the code should be fine but I don't understand what's wrong.
I'm fairly new to Arduino so I don't really understand all aspects
this is the code I'm running.
It might be worth mentioning that I'm running the computer and the ESP32 wifi on my iPhone Hotspot.
#include "WiFi.h"
#define led 2
#include <Thread.h>
#include <WiFiUdp.h>
const char* ssid = "ssid";
const char* password = "password";
char packetBuffer[255];
WiFiUDP Udp;
WiFiServer wifiServer(10100);
Thread myThread = Thread();
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
  myThread.enabled = true;
  myThread.setInterval(10);
  myThread.ThreadName = "myThread tag";
  myThread.onRun(listen_broad);
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  wifiServer.begin();
  Udp.begin(10100);
void listen_broad(){
  int packetSize = Udp.parsePacket();
  if (packetSize){
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remoteIp = Udp.remoteIP();
    Serial.print(remoteIp);
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    int len = Udp.read(packetBuffer, 255);
    if (len > 0) packetBuffer[len] = 0;
    Serial.println("Contents:");
    Serial.println(packetBuffer);
    // send a reply, to the IP address and port that sent us the packet we received
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    int i = 0;
    char ReplyBuffer[] = "ACK";
    while (ReplyBuffer[i] != 0)
    Udp.write((uint8_t)ReplyBuffer[i++]);
    Udp.endPacket();
  if(myThread.shouldRun()){
    myThread.run();
  WiFiClient client = wifiServer.available();
  if (client) {
    client.write("nonono");
    while (client.connected()) {
      while (client.available()>0){
        char c = client.read();
        Serial.write(c);
        switch (c) {
          case '1':
            //TOGGLE LIGHT//
            if(digitalRead(led)){
              Serial.write("Turning OFF");
            else{
              Serial.write("Turning ON");
              digitalWrite(led, HIGH);
          case '2':
            //CLOSE////////
            client.stop();
          default:
            Serial.write("DEF");
      delay(10);
    Serial.println("Client disconnected");
Post the serial output you got!
It was just a print of the data in the UDP message I received and a message saying connected to wifi and the local IP
Then run the sketch again and post the exact output you get!
It might be a good idea to print the return value of Udp.endPacket() to know if the ESP thinks it sent the packet.
