ESP32 Client and Server programming help
I am trying a project from Random Nerd Tutorials which involves using 2 x ESP32's in a Client/Server mode. The project calls for a BME280 Sensor which I do not have so I am attempting to substitute a DHT11 Sensor.
I have come unstuck with the code and have an Error Message which I do not understand (Im completely new at the programming).
This is a copy of the error message I am getting, can anyone please assist and possibly comment if I have made the substitution of the DHT11 correctly.
Arduino: 1.8.19 (Mac OS X), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
/Users/melchiorrabie/Documents/Arduino/Mel_Client_Server_ver1/Mel_Client_Server_ver1.ino: In function 'void setup()':
Mel_Client_Server_ver1:67:10: error: void value not ignored as it ought to be
   status = dht_sensor.begin(0x76);
Multiple libraries were found for "WiFi.h"
 Used: /Users/melchiorrabie/Library/Arduino15/packages/esp32/hardware/esp32/1.0.6/libraries/WiFi
 Not used: /Users/melchiorrabie/Desktop/Arduino.app/Contents/Java/libraries/WiFi
exit status 1
option enabled in File -> Preferences.
 or paste code here
[code]
  Rui Santos
  Complete project details at https://RandomNerdTutorials.com/esp32-client-server-wi-fi/
  Permission is hereby granted, free of charge, to any person obtaining a copy
  of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all
  copies or substantial portions of the Software.
// Import required libraries
#include "WiFi.h"
#include "ESPAsyncWebServer.h"
#include <DHT.h>
#define DHT_SENSOR_PIN  27 // ESP32 pin GIOP27 connected to DHT11 sensor
#define DHT_SENSOR_TYPE DHT11
DHT dht_sensor(DHT_SENSOR_PIN, DHT_SENSOR_TYPE);
// Set your access point network credentials
const char* ssid = "ESP32-Access-Point";
const char* password = "123456789";
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readTemp() {
  return String(dht_sensor.readTemperature());
  //return String(1.8 * DHT.readTemperature() + 32);
String readHumi() {
  return String(dht_sensor.readHumidity());
  // Serial port for debugging purposes
  // Setting the ESP as an access point
  Serial.print("Setting AP (Access Point)…");
  // Remove the password parameter, if you want the AP (Access Point) to be open
  WiFi.softAP(ssid, password);
  IPAddress IP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(IP);
  server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/plain", readTemp().c_str());
  server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest * request) {
    request->send_P(200, "text/plain", readHumi().c_str());
  bool status;
  // default settings
  // (you can also pass in a Wire library object like &Wire2)
  if (!status) {
    Serial.println("Could not find a valid DHT11 sensor, check wiring!");
    while (1);
  // Start server
  server.begin();
[/code]
Easy, just look at the example sketches from the DHT library that you installed to see how it's supposed to be used. You seem to have either just guessed, or tried to modify the BMP library calls.
@melrabie, your topic has been moved to a more suitable location on the forum as this has nothing to do with Avrdude, stk500 or Bootloader
