ESP32 Dev Kit v1 Board
Software Audrino IDE
ESP32 v2.0.1.7
ESP32Servo by Kevin Harrington
PS3 Controller Host by Jeffery van Pernis
Here is the code that was written for the forklift that doesn't work the greatest.
#include <Ps3Controller.h>
#include <ESP32Servo.h> // by Kevin Harrington
#define steeringServoPin 23
#define mastTiltServoPin 22
#define cabLights 32
#define auxLights 33
#define mastMotor0 25 // Used for controlling auxiliary attachment movement
#define mastMotor1 26 // Used for controlling auxiliary attachment movement
#define auxAttach0 18 // Used for controlling auxiliary attachment movement
#define auxAttach1 17 // Used for controlling auxiliary attachment movement
#define leftMotor0 21 // Used for controlling the left motor movement
#define leftMotor1 19 // Used for controlling the left motor movement
#define rightMotor0 33 // Used for controlling the right motor movementc:\Users\JohnC\Desktop\SOLIDWORKS Connected.lnk
#define rightMotor1 32 // Used for controlling the right motor movement
Servo steeringServo;
Servo mastTiltServo;
int servoDelay = 0;
int lightSwitchTime = 0;
float adjustedSteeringValue = 86;
float adjustedThrottleValue = 0;
float steeringAdjustment = 1;
int steeringTrim = 0;
int mastTiltValue = 90;
int mastTilt = 0;
bool lightsOn = false;
bool moveMastTiltServoDown = false;
bool moveMastTiltServoUp = false;
bool hardLeft;
bool hardRight;
void notify() {
//--------------- Digital D-pad button events --------------
if (Ps3.event.button_down.up) {
Serial.println("Started pressing the up button");
mastTilt = 1;
if (Ps3.event.button_down.down) {
Serial.println("Started pressing the down button");
mastTilt = 2;
if (Ps3.event.button_up.up) {
Serial.println("Released the up button");
mastTilt = 0;
if (Ps3.event.button_up.down) {
Serial.println("Released the down button");
mastTilt = 0;
//---------------- Analog stick value events ---------------
if (abs(Ps3.event.analog_changed.stick.lx) + abs(Ps3.event.analog_changed.stick.ly) > 2) {
// Serial.print("Moved the left stick:");
// Serial.print(" x=");
// Serial.print(Ps3.data.analog.stick.lx, DEC);
// Serial.print(" y=");
// Serial.print(Ps3.data.analog.stick.ly, DEC);
// Serial.println();
int LYValue = Ps3.data.analog.stick.ly * 2;
processThrottle(LYValue);
if (abs(Ps3.event.analog_changed.stick.rx) + abs(Ps3.event.analog_changed.stick.ry) > 2) {
// Serial.print("Moved the right stick:");
// Serial.print(Ps3.data.analog.stick.rx, DEC);
// Serial.print(Ps3.data.analog.stick.ry, DEC);
int RXValue = (Ps3.data.analog.stick.rx);
adjustedSteeringValue = 90 - (RXValue / 3);
int RYValue = (Ps3.data.analog.stick.ry);
steeringServo.write(adjustedSteeringValue + steeringTrim);
if (adjustedSteeringValue > 100) {
steeringAdjustment = ((200 - adjustedSteeringValue) / 100);
} else if (adjustedSteeringValue < 80) {
steeringAdjustment = ((200 - (90 + (90 - adjustedSteeringValue))) / 100);
processThrottle(adjustedThrottleValue);
if (RYValue > 100 || RYValue < -100) {
moveMotor(mastMotor0, mastMotor1, RYValue);
moveMotor(mastMotor0, mastMotor1, 0);
//------------------------shoulder buttons events ----------------
if (Ps3.event.button_down.r1) {
if (steeringTrim < 20) {
steeringTrim = steeringTrim + 2;
delay(50);
if (Ps3.event.button_down.l1) {
if (steeringTrim > -20) {
steeringTrim = steeringTrim - 2;
delay(50);
//------------------------trigger buttons events ----------------
if (Ps3.event.button_down.l2) {
hardLeft = true;
delay(10);
Serial.println("Started pressing the left trigger button");
if (Ps3.event.button_up.l2) {
hardLeft = false;
delay(10);
Serial.println("Released the left trigger button");
if (Ps3.event.button_down.r2) {
hardRight = true;
delay(10);
Serial.println("Started pressing the right trigger button");
if (Ps3.event.button_up.r2) {
hardRight = false;
delay(10);
Serial.println("Released the right trigger button");
//------------------------ Joystick Button events ----------------
if (Ps3.event.button_down.r3) {
if ((millis() - lightSwitchTime) > 200) {
if (lightsOn) {
digitalWrite(auxAttach0, LOW);
digitalWrite(auxAttach1, LOW);
lightsOn = false;
digitalWrite(auxAttach0, HIGH);
lightsOn = true;
lightSwitchTime = millis();
Serial.println("Started pressing the right stick button");
if (servoDelay >= 5) {
if (mastTilt == 1 && mastTiltValue >= 10 && mastTiltValue < 170) {
mastTiltValue = mastTiltValue + 1;
mastTiltServo.write(mastTiltValue);
servoDelay = 0;
if (mastTilt == 2 && mastTiltValue <= 170 && mastTiltValue > 10) {
mastTiltValue = mastTiltValue - 1;
servoDelay = 0;
servoDelay++;
void processThrottle(int throttleValue) {
adjustedThrottleValue = throttleValue;
if (adjustedThrottleValue > 15 || adjustedThrottleValue < -15) {
if (hardRight) {
moveMotor(rightMotor0, rightMotor1, -1 * (adjustedThrottleValue * steeringAdjustment));
} else if (hardLeft) {
moveMotor(leftMotor0, leftMotor1, -1 * (adjustedThrottleValue * steeringAdjustment));
} else if (adjustedSteeringValue > 100) {
moveMotor(leftMotor0, leftMotor1, adjustedThrottleValue * steeringAdjustment);
moveMotor(rightMotor0, rightMotor1, adjustedThrottleValue);
moveMotor(leftMotor0, leftMotor1, adjustedThrottleValue);
moveMotor(rightMotor0, rightMotor1, adjustedThrottleValue * steeringAdjustment);
moveMotor(leftMotor0, leftMotor1, 0);
moveMotor(rightMotor0, rightMotor1, 0);
void moveMotor(int motorPin0, int motorPin1, int velocity) {
if (velocity > 15) {
analogWrite(motorPin0, velocity);
analogWrite(motorPin1, LOW);
} else if (velocity < -15) {
analogWrite(motorPin0, LOW);
analogWrite(motorPin1, (-1 * velocity));
analogWrite(motorPin0, 0);
analogWrite(motorPin1, 0);
void onConnect() {
Serial.println("Connected.");
Ps3.attach(notify);
Ps3.attachOnConnect(onConnect);
Ps3.begin("8c:7c:b5:fc:3b:06");
Serial.println("Ready.");
pinMode(auxAttach0, OUTPUT);
pinMode(auxAttach1, OUTPUT);
pinMode(leftMotor0, OUTPUT);
pinMode(leftMotor1, OUTPUT);
pinMode(rightMotor0, OUTPUT);
pinMode(rightMotor1, OUTPUT);
pinMode(mastMotor0, OUTPUT);
pinMode(mastMotor1, OUTPUT);
steeringServo.attach(steeringServoPin);
steeringServo.write(adjustedSteeringValue);
mastTiltServo.attach(mastTiltServoPin);
if (!Ps3.isConnected())
return;
Here is the code that works well minus the drive motors wont go as noted in my above post
// --- Pin Definitions ---
#define mastMotor0 25 // Fork Lift Motor A
#define mastMotor1 26 // Fork Lift Motor B
#define leftMotor0 21 // Left Motor Forward
#define leftMotor1 19 // Left Motor Reverse
#define rightMotor0 33 // Right Motor Forward
#define rightMotor1 32 // Right Motor Reverse
// --- Servo Objects ---
// --- State Variables ---
int mastTiltDirection = 0;
int servoDelay = 0;
// --- Constants ---
const int MAST_MIN = 10;
const int MAST_MAX = 170;
const int MAST_STEP = 3;
const int MAST_INTERVAL = 1;
const float steeringCenter = 90;
const int DEAD_ZONE = 10;
// --- PS3 Events ---
void onConnect() {
Serial.println("PS3 controller connected!");
void notify() {
if (Ps3.event.button_down.up) mastTiltDirection = 1;
if (Ps3.event.button_down.down) mastTiltDirection = 2;
if (Ps3.event.button_up.up || Ps3.event.button_up.down) mastTiltDirection = 0;
if (Ps3.event.button_down.r1 && steeringTrim < 20) steeringTrim += 2;
if (Ps3.event.button_down.l1 && steeringTrim > -20) steeringTrim -= 2;
// --- Setup ---
Ps3.attach(notify);
Ps3.begin("8c:7c:b5:fc:3b:39"); // Your PS3 controller MAC
pinMode(cabLights, OUTPUT);
pinMode(auxLights, OUTPUT);
steeringServo.write(steeringCenter);
Serial.println("Waiting for PS3 controller...");
// --- Motor Control Helper ---
void moveMotor(int pinFWD, int pinREV, int speed) {
speed = constrain(speed, -255, 255);
if (speed > 0) {
analogWrite(pinFWD, speed);
analogWrite(pinREV, 0);
} else if (speed < 0) {
analogWrite(pinFWD, 0);
analogWrite(pinREV, -speed);
// --- Main Loop ---
if (!Ps3.isConnected()) return;
// --- Drive (Left Stick Y) ---
int ly = Ps3.data.analog.stick.ly;
int drive = abs(ly) > DEAD_ZONE ? map(ly, -128, 127, -255, 255) : 0; // Inverted based on your test
// --- Steering (Right Stick X) ---
int steer = Ps3.data.analog.stick.rx;
float steerAdjust = abs(steer) > DEAD_ZONE ? steer / 128.0 : 0;
// Calculate left and right power
int leftPower = constrain(drive + (steerAdjust * abs(drive)), -255, 255);
int rightPower = constrain(drive - (steerAdjust * abs(drive)), -255, 255);
moveMotor(leftMotor0, leftMotor1, leftPower);
moveMotor(rightMotor0, rightMotor1, rightPower);
// --- Steering Servo ---
float steeringAngle = steeringCenter - (steer / 3.0) + steeringTrim;
steeringServo.write(constrain(steeringAngle, 45, 135));
// --- Mast Tilt (D-pad) ---
if (servoDelay >= MAST_INTERVAL) {
if (mastTiltDirection == 1 && mastTiltValue < MAST_MAX) {
mastTiltValue += MAST_STEP;
servoDelay = 0;
} else if (mastTiltDirection == 2 && mastTiltValue > MAST_MIN) {
mastTiltValue -= MAST_STEP;
servoDelay = 0;
servoDelay++;
// --- Fork Lift (Right Stick Y) ---
int ry = Ps3.data.analog.stick.ry;
int fork = abs(ry) > DEAD_ZONE ? map(ry, -128, 127, -255, 255) : 0;
moveMotor(mastMotor0, mastMotor1, fork);
delay(20);
Please let me know if the electronics schematics are needed or if this code is sufficient. I can also provide pin numbers items are on.
