esp32 code
hi, so I nned to convert a code using in a esp8266 to be useful in a esp32 but I don,t know what should I change …please can you help me …I really need it in my final project.
so this is the code:
//Prateek
//www.prateeks.in
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include “MAX30100_PulseOximeter.h”
#include <SimpleTimer.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
char auth = “6497f4ca052e43e3817c1e7157926730”; // You should get Auth Token in the Blynk App.
char ssid = “JustDo”; // Your WiFi credentials.
char pass = “par12345”;
#define REPORTING_PERIOD_MS 3000
SimpleTimer timer;
PulseOximeter pox;
uint32_t tsLastReport = 0;
void onBeatDetected()
Wire.begin(D2, D1);
lcd.begin();
lcd.backlight();
lcd.setCursor(3, 0);
lcd.print(“Welcome To”);
lcd.setCursor(0, 1);
lcd.print(“JustDoElectronic”);
delay(3000);
lcd.clear();
lcd.setCursor(6, 0);
lcd.print(“IoT”);
lcd.setCursor(1, 1);
lcd.print(“Pulse Oximeter”);
delay(3000);
lcd.clear();
Blynk.begin(auth, ssid, pass);
Serial.print(“Initializing pulse oximeter…”);
// Initialize the PulseOximeter instance
// Failures are generally due to an improper I2C wiring, missing power supply
// or wrong target chip
if (!pox.begin()) {
Serial.println(“FAILED”);
for (;;);
Serial.println(“SUCCESS”);
digitalWrite(1, HIGH);
pox.setIRLedCurrent(MAX30100_LED_CURR_24MA);
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
timer.setInterval(1000L, getSendData);
timer.run(); // Initiates SimpleTimer
Blynk.run();
// Make sure to call update as fast as possible
pox.update();
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
// to computer serial monitor
Serial.print(“BPM: “);
Serial.print(pox.getHeartRate());
//blue.println(”\n”);
Serial.print(" SpO2: “);
Serial.print(pox.getSpO2());
Serial.print(”%");
Serial.println("\n");
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(“BPM: “);
lcd.setCursor(10, 0);
lcd.print(pox.getHeartRate());
lcd.print(“SpO2:”);
lcd.setCursor(10, 1);
lcd.print(pox.getSpO2());
lcd.setCursor(14, 1);
lcd.print(”%”);
Blynk.virtualWrite(V2, pox.getHeartRate() );
Blynk.virtualWrite(V3, pox.getSpO2());
tsLastReport = millis();
void getSendData()
@amal_amama
Your topic was Moved to it's current location / section as it is more suitable and certainly NOT website related !
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
They are both links to areas you SKIPPED when coming to the forum.
