It's probably a "new guy thing," but I need help with an error when attempting to upload to my ESP32 WROOM board. The error that comes in is:
<Traceback (most recent call last):
File "esptool/loader.py", line 57, in <module>
File "PyInstaller/loader/pyimod02_importers.py", line 352, in exec_module
File "serial/tools/list_ports.py", line 31, in <module>
File "serial/tools/list_ports_posix.py", line 33, in <module>
File "serial/tools/list_ports_osx.py", line 26, in <module>
File "ctypes/__init__.py", line 7, in <module>
ImportError: dlopen(/var/folders/bp/0rt1slds65sdr24j6vmrcrbw0000gn/T/_MEIZLfcWU/lib-dynload/_ctypes.cpython-38-darwin.so, 2): Symbol not found: _ffi_closure_alloc
Referenced from: /var/folders/bp/0rt1slds65sdr24j6vmrcrbw0000gn/T/_MEIZLfcWU/lib-dynload/_ctypes.cpython-38-darwin.so (which was built for Mac OS X 10.15)
Expected in: /usr/lib/libffi.dylib
in /var/folders/bp/0rt1slds65sdr24j6vmrcrbw0000gn/T/_MEIZLfcWU/lib-dynload/_ctypes.cpython-38-darwin.so
During handling of the above exception, another exception occurred:
File "esptool.py", line 31, in <module>
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "esptool/__init__.py", line 41, in <module>
File "esptool/cmds.py", line 14, in <module>
File "esptool/bin_image.py", line 14, in <module>
File "esptool/loader.py", line 62, in <module>
AttributeError: module 'sys' has no attribute 'VERSION'
[33982] Failed to execute script 'esptool' due to unhandled exception!
exit status 1
Compilation error: exit status 1/>
For a program, I simply used the basic void setup / void loop with no other code to rule out syntax errors.
I am using Arduino Version 2.2.1
