I am trying to run following sketch on ESP32 but get compile error.
What could be the solution to resolve this issue ?
C:\Users\ebhynes\AppData\Local\Temp\arduino_modified_sketch_647803\sketch_apr04a.ino: In function 'void setup()':
sketch_apr04a:17:29: error: call of overloaded 'BSSID(int)' is ambiguous
17 | values[i] = WiFi.BSSID(0)[i];
In file included from C:\Users\ebhynes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src/WiFi.h:34,
from C:\Users\ebhynes\AppData\Local\Temp\arduino_modified_sketch_647803\sketch_apr04a.ino:1:
C:\Users\ebhynes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src/WiFiSTA.h:171:12: note: candidate: 'uint8_t* WiFiSTAClass::BSSID(uint8_t*)'
171 | uint8_t *BSSID(uint8_t *bssid = NULL);
In file included from C:\Users\ebhynes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src/WiFi.h:36:
C:\Users\ebhynes\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.2.0\libraries\WiFi\src/WiFiScan.h:52:12: note: candidate: 'uint8_t* WiFiScanClass::BSSID(uint8_t, uint8_t*)'
52 | uint8_t *BSSID(uint8_t networkItem, uint8_t *bssid = NULL);
Sketch:
#include <WiFi.h>
//int16_t scanNetworks(bool async = false, bool show_hidden = false, bool passive = false, uint32_t max_ms_per_chan = 300, uint8_t channel = 0, const char * ssid=nullptr, const uint8_t * bssid=nullptr);
int n = WiFi.scanNetworks(true, false, false, 5, 7, "HTM");
delay(10); // Minimum 10 milliseonds delay required to reliably receive message from Gateway.
for (int i = 0; i < 4; i++)
uint8_t values[4];
void loop() { }
