esp32 Connect Failure
Hi All,
I have an ESP32 that I have programmed/reprogrammed several times over USB. I have removed it, not connected to anything else and now it will not upload the program saying that esptool wont open and the board is not connected. I can select the com port in Arduino IDE and I see and access the board in device manager, I am using the same cable as an hour ago but have tried several other cables with same result.
I have also tried pressing the boot button, holding it down, and every other combination I can think of. Nothing has changed from an hour ago when everything was working fine so I am at a loss.
Any Ideas would be welcome as I have tried every troubleshoot that I can think of.
The Error:-
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
Sketch uses 215817 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 15492 bytes (4%) of dynamic memory, leaving 312188 bytes for local variables. Maximum is 327680 bytes.
esptool.py v2.6
Serial port COM14
Traceback (most recent call last):
File "esptool.py", line 2959, in
File "esptool.py", line 2952, in _main
File "esptool.py", line 2652, in main
File "esptool.py", line 222, in init
File "site-packages\serial_init_.py", line 88, in serial_for_url
File "site-packages\serial\serialwin32.py", line 62, in open
serial.serialutil.SerialException: could not open port 'COM14': WindowsError(5, 'Access is denied.')
Failed to execute script esptool
the selected serial port Failed to execute script esptool
does not exist or your board is not connected
option enabled in File -> Preferences.
Have you tried rebooting your computer ?
unplug the USB, start the IDE, and then plug the USB in.
The issue is in the esptool.py what version of python (if any) do you have installed ?
