Esp32 crashed by changed bool var without logic
Hello. I use ESP32-wroom DevKit
I connect display to this board and display some info. On some period it's show users info about timeout error.
In main loop I use this construction, to display error:
 if (payTimeOut)
    payTimeOut = false;
    cancel_session = true;
    showTimeOutErr ();
    delay(5000);
    mainScreen ();
    pirGet = 0;
    person_hear = false;
    startPay = false;
    persTimeOut = 0;
on setup
bool payTimeOut = false;
void setup(void) {
  Serial.setTimeout(100);
  xTaskCreate(
    syncTask
    ,  "syncTask" // A name just for humans
    ,  24576        // The stack size can be checked by calling `uxHighWaterMark = uxTaskGetStackHighWaterMark(NULL);`
    ,  NULL // Task parameter which can modify the task behavior. This must be passed as pointer to void.
    ,  2  // Priority
    ,  NULL // Task handle is not used here - simply pass NULL
payTimeOut is changed in other while loop which not loaded now, but after some time work esp32 crashed. Exception Decoder show:
It's really make me crazy. It's was not any change for payTimeOut then it's impossible to call showTimeOutErr.
But if I call showTimeOutErr by myseft - it work correctly - nothing crashed...
If anyone have any idea in what can be trouble, please help! Thanks
Please post a complete sketch, if not the actual sketch you are working on then a reduced sketch that illustrates your problem.
I don't know who can help with a while statement that is nowhere in sight.
a7
