RPLidar on ESP32
#include <HardwareSerial.h>
//HardwareSerial LiSerial(1);
#include "esp32-hal-ledc.h"
// This sketch code is based on the RPLIDAR driver library provided by RoboPeak
#include <RPLidar.h>
// You need to create an driver instance
RPLidar lidar;
// bind the RPLIDAR driver to the ESP32 hardware serial2
lidar.begin(Serial2);
if (IS_OK(lidar.waitPoint())) {
//perform data processing here...
Serial.println("Lidar Get info...");
delay(15);
// try to detect RPLIDAR...
rplidar_response_device_info_t info;
if (IS_OK(lidar.getDeviceInfo(info, 100))) {
// detected...
Serial.println("Lidar Detected...");
lidar.startScan();
// start motor rotating at max allowed speed
Serial.println(int(lidar.getCurrentPoint().distance));
error mesage
23:08:19.520 -> Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
23:08:19.520 -> Core 1 register dump:
23:08:19.520 -> PC : 0x400d1b95 PS : 0x00060330 A0 : 0x800d0fe8 A1 : 0x3ffb1ee0
23:08:19.520 -> A2 : 0x00000f84 A3 : 0xba400000 A4 : 0x00000002 A5 : 0x0000ff00
23:08:19.520 -> A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000f84 A9 : 0x00000000
23:08:19.552 -> A10 : 0x00000000 A11 : 0x3f400532 A12 : 0x00000050 A13 : 0x0000ff00
23:08:19.552 -> A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000000a EXCCAUSE: 0x0000001c
23:08:19.552 -> EXCVADDR: 0x00000f90 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
23:08:19.552 ->
23:08:19.552 -> ELF file SHA256: 0000000000000000
23:08:19.584 ->
23:08:19.584 -> Backtrace: 0x400d1b95:0x3ffb1ee0 0x400d0fe5:0x3ffb1f00 0x400d1024:0x3ffb1f20 0x400d0dd5:0x3ffb1f40 0x400d0cac:0x3ffb1f70 0x400d226d:0x3ffb1fb0 0x40086125:0x3ffb1fd0
23:08:19.584 ->
23:08:19.584 -> Rebooting...
23:08:19.584 -> ets Jun 8 2016 00:22:57
23:08:19.584 ->
23:08:19.584 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
23:08:19.584 -> configsip: 0, SPIWP:0xee
23:08:19.584 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
23:08:19.625 -> mode:DOUT, clock div:2
23:08:19.625 -> load:0x3fff0018,len:4
23:08:19.625 -> load:0x3fff001c,len:1044
23:08:19.625 -> load:0x40078000,len:10124
23:08:19.625 -> load:0x40080400,len:5828
23:08:19.625 -> entry 0x400806a8
23:08:19.751 -> [V][HardwareSerial.cpp:91] end(): pins 0 0
