Hi
my ESP32 WROOM have a sleep time of 180 minutes, wakes up and send a lora package to my receiver, receiver then send to home assistant.
This 180 min is not 180 min:
Packages received in Home Assistant:
sensor.kube_1_pakke_nr, 22,2024-07-09T22: 18:43.315
sensor.kube_1_pakke_nr, 23,2024-07-10T01: 17:26.707
sensor.kube_1_pakke_nr, 24,2024-07-10T04: 16:37.606
Here are the time differences between each consecutive packet in minutes and seconds:
Between packet 22 and 23:
- 178 minutes and 43.392 seconds
Between packet 23 and 24:
- 179 minutes and 10.899 seconds
Questions
Why am I receiving packages in
- not same sleep time between packages?
- less than 180 minutes?
M
We need to see your code that sends the messages.
Hi
before I share, a question.
The code is not dependent of a certain status of a sensor, it read 5 sensors, and send sensor data then deep sleep.
Q:
I expect the code to run in the same manner each time it wakes up, and use same time (identical) each time, is this a wrong conclusion?
Personally, I have no idea, because I can’t see how the code operates.
Others may be better guessers than I am.
I may not solve the problem for you, but until I can see what’s causing it, neither of us will know.
system
Closed
5
