Newbie here but Ive spent 10 hours working on this and I need help.
My goal is to play mp3 files from a dfplayer to the bluetooth amp when a IR sensor its tripped.
I bought the "EC Buying ESP32-DevKitC Development Board ,ESP32 Development Board Equipped with WROOM-32D Module Integrated WiFi Bluetooth Module Microprocessor Interface SPI I2C I2S Suitable for Arduino"
The amp- " DAMGOO Bluetooth Amplifier Board, 100W+100W Peak Output Power, 2.0 Channel DC:8-24V, Password Free Connect, BT 5.0 AMP Board for DIY Wireless Speakers Board"
I can get my phone and PC to find both bluetooth signals but i cant get the ESP32 to connect to the amp(Wuzhi Audio). Do I need to use the UUID for the amp instead of its name? Do i need to change it to bluetoothLE instead of classic? Is my code not reaching out to bluetooth like it should? I tried using "ESP32 dev module and ESP32 WROOM DA module and no luck.
my code -
#include <DFRobotDFPlayerMini.h>
#include <IRremote.h>
#include "BluetoothSerial.h"
BluetoothSerial SerialBT;
DFRobotDFPlayerMini mp3;
IRrecv irrecv(18); // IR Optocoupler Module connected to GPIO 18
bool connectedToAmplifier = false;
// Replace "Wuzhi Audio" with the actual device name of your amplifier
const char* amplifierName = "Wuzhi_Audio";
unsigned long startTime = 0; // Variable to record the start time of connection attempts
const unsigned long connectionTimeout = 15000; // 15 seconds
// Initialize Bluetooth Serial
SerialBT.begin("ESP32_A2DP"); // Bluetooth device name
// Initialize DFPlayer Mini (TX on pin 17, RX on pin 16)
mp3.begin(Serial2);
// Initialize IR Optocoupler Module
irrecv.enableIRIn();
// Connect to Bluetooth amplifier
connectBluetoothAmplifier();
// Your logic here
if (connectedToAmplifier) {
if (irrecv.decode()) {
// IR signal received, trigger action (e.g., play "short crank mp3" from DFPlayer Mini)
playMp3FromDFPlayer();
irrecv.resume(); // Receive the next value
