Esp32 DFPlayer mini not connecting
I am currently trying to connect an esp32 to the DFPlayer mini, but i am unable to get a connection to the DFPlayer.
However I am able to play music with the Arduino UNO in the following setup:
This is the base setup i use with the esp. Which isnt working:
I tried a lot of setups with the esp32:
  • Different RX, TX pins (26, 27; 14, 15)
  • Different supply voltages (3V3, 5V)
  • with RX resistor (1k, 10k, 100k) and (1k + 680Ohm, as seen in picture)
The following code returns "Connecting to DFPlayer Mini failed!".
I am 100% sure i connected everything right, as it is working with a specific setup on the arduino.
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Use pins 2 and 3 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 10; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 11; // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the Player object
DFRobotDFPlayerMini player;
  // Init USB serial port for debugging
  // Init serial port for DFPlayer Mini
  softwareSerial.begin(9600);
  // Start communication with DFPlayer Mini
  if (player.begin(softwareSerial)) {
    Serial.println("OK");
    // Set volume to maximum (0 to 30).
    player.volume(30);
    // Play the "0001.mp3" in the "mp3" folder on the SD card
    player.playMp3Folder(1);
    Serial.println("Connecting to DFPlayer Mini failed!");
Nothing works. I even had problems with the arduino. Non of the setups i found online, expect the one from the picture, worked.
Anybody have a clue how i can solve this?
Please post your test sketch that you used on the ESP32
You should never post in the Uncategorised section.
It says so in the description of the section. Therefore I have moved your post here.
You might want to look at this How to get the best out of this forum before you proceed any further.
ESP32 topic, UNO wiring diagram.
Oh well.
Try my sketch in post #33 of this thread.
https://forum.arduino.cc/t/df-player-problems/1256694/32
Not working. I dont get an "Connecting to DFPlayer Mini failed!" error anymore.
But even if the player is physically not connected the code is not returning an error.
So i assuem its juts dissabling validation
With the following setup:
My oscilloscope is showing the following Arduino TX pin signal:
Shoudlnt the signal go down to 0V?
SoftwareSerial does not work with ESP32 - if that is what you're using.
If you are using an ESP32 then you should be using its UART (i.e. Serial2).
Thanks a lot.
With Serial2 it looks a lot better.
But its still not working.
This is my current code
// My edit of yours. Compiles & runs here, Thu 9 May 2024 12:17.
//#include "Arduino.h" // Redundant, so I usually omit.
//#include <SoftwareSerial.h> // You're no longer using it.
DFRobotDFPlayerMini myDFPlayer;
// void printDetail(uint8_t type, int value);
// I usually find that function and and its lengthy definition
// superfluous. Replace both later if you want.
  Serial2.begin(9600);
  delay(200); // My preference for print stability
  // if (!myDFPlayer.begin(Serial1, /*isACK = */true, /*doReset = */true)) {  //Use serial to communicate with mp3.
  // What was your source of that? I've removed the test entirely for
  // now, assuming your priority is getting it working.
  if (!myDFPlayer.begin(Serial2)) {// Start communication with DFPlayer
  // myDFPlayer.begin(Serial1, true, false); // Start communication with DFPlayer
    Serial.println("ERROR");
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  delay(1000); // Add this to allow player to fully initialise
  myDFPlayer.volume(15);  //Set volume value. From 0 to 30
  Serial.println("setup ended"); // I like this reassurance
  //  myDFPlayer.play(001); // Ensure that your files have been renamed to 001, 002, etc.
  myDFPlayer.play(1);
  // Note: the 'name' is irrelevant to the module (but not to you,
  // of course). That command plays the first file that was copied
  // or moved to the uSD;  chronologically. Could be called
  // anything.
  delay(5000); // If you actually want to hear anything each time
  // through the loop! To hear entire tracks...another discussion.
Solved it now with the following wiring:
ESP PIN 4 = TX -> Player RX
ESP PIN5 = RX -> Player TX
#define RXD2 5
#define TXD2 4
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  myDFPlayer.play(1);
  // anything.
Used the wiring of this github project.
No idea why it worked with these pins but not with any other pin.
I have the following esp. Maybe it has something to do with it.
ESP32 Chip model = ESP32-D0WDQ6-V3 Rev 3
Maybe someone smarter can explain to me why it only works with the end setup.
You're saying it won't work with other RXD2, TXD2 ?
16, 17 ?
Did you read the thread, which was using a Mega 2560? Or just copy the code without change. My sketch used Serial 1 (pins 18/19) so you’d have to change for your board. If that’s an ESP32 why does your schematic show a UNO?
Also, I’m not clear which version of my sketch you used: the abbreviated one (without the test) or my EDIT? That is your original with my one line correction., so that does include the module test.
