ESP32 disconnect after sending data once to MQTT
Hello,
I am trying to send data from Esp32 to MQTT. So far, I have been successful in sending the data once but after that Esp32 does not connects to MQTT to send further data. I have tried checking and debugging my code, but I encounter the same problem over and over again. Kindly help me in this regard.
I am posting my code for Esp32 here:
#include <HardwareSerial.h>
#include <PubSubClient.h> //Connect and publish data to the MQTT broker
#include <WiFi.h> //Enables Esp32 to connect to the local network(via WiFi)
#define RXD2 16
#define TXD2 17
//char myRcvChar;
//WiFi
const char* ssid = "xxxxxxxxx";
const char* wifi_password = "xxxxxxxxx";
//MQTT
const char* mqtt_server = "192.168.0.106";
const char* message_topic = "test/esp32/message";
//const char* bending_topic = "exoskeleton/walking/bending";
//const char* streching_topic = "exoskeleton/walking/streching";
const char* mqtt_username = "bilal"; //MQTT username
const char* mqtt_password = "mqtt"; //MQTT password
const char* clientID = "client_first message";
//Initialise the Wifi and MQTT Client objects
WiFiClient wifiClient;
//1883 is the listener port for the broker
PubSubClient client(mqtt_server,1883,wifiClient);
//Custom function to connect to the MQTT broker via WiFi
void connect_MQTT(){
  Serial.print("Connecting to ");
  Serial.println(ssid);
  //Connect to the WiFi
  WiFi.begin(ssid, wifi_password);
  //wait until the connection has been confirmed before continuing
  while(WiFi.status()!= WL_CONNECTED){
    Serial.print(".");
  //Debugging-Output the IP Address of the ESP32
  Serial.println("WiFi connected");
  Serial.println("IP Address");
  //Connect to MQTT Broker
  //client.connect returns a boolean value to let us know if the connection was successful
  //if the connection is failing, make sure you are using the correct MQTT Username and Password
  if(client.connect(clientID,mqtt_username,mqtt_password)){
    Serial.println("Connected to MQTT Broker");
  else{
      Serial.println("Connection to MQTT Broker failed...");
void setup(){
  //Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
 //char myRcvchar;
  connect_MQTT();
  Serial.setTimeout(1000);
  //Serial.println("Data Received: ");
  //Serial.println(Serial2.readStringUntil('\n'));
  const char* message = "Hello";
  Serial.println("Message Received: ");
  Serial.println(message);
  //MQTT can only transmit strings
  String ms = "Mess: "+String((char*)message);
  //Publish to MQTT broker
  if(client.publish(message_topic, String(message).c_str())){
    Serial.println("Message sent");
  //Again client.publish will return boolean value depending on whether it succeded or not.
  //if the message failed to send, try again, as the connection might have broken
  else{
    Serial.println("Message failed to send. Reconnecting to MQTT Broker and trying again");
    client.connect(clientID,mqtt_username,mqtt_password);
    delay(10); //This delay ensures that client.publish does not clash with client.connect call
    client.publish(message_topic,String(message).c_str());
  client.disconnect(); //disconnect from the MQTT broker
  delay(1000*60); //print new values every 1 minutes
On each MQTT client disconnect, it seems to be assmumed that the WiFi has disconnected as well because each time connect_MQTT(); is ran it connects to WiFi even if its still connected because their was no WiFi disconnect. Such a operation is sure to cause wifi stack issues. Why not, after disconnecting from the MQTT broker, the op disconnect from wifi as well?
I want it to stay connected to the Wi-Fi and send data/messages but every time I see the serial monitor it shows me that “Connection failed to MQTT broker” but somehow I see the messages in the command line of Raspberry Pi.
I commented out:
//client.disconnect();
//delay(1000*60);
And added:
client.loop();
Can you tell me how not to see the message on serial monitor about the “Connection failed”??
Does your code check to see if WiFi is connected?
If WiFi is disconnected then MQTT will be disconnected.
#include <WiFi.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "time.h"
#include <ESP32Time.h>
ESP32Time rtc;
hw_timer_t * timer = NULL;
EventGroupHandle_t eg;
#define evtDoDisplay ( 1 << 1 )
#define evtDoTheMQTT_Watch   ( 1 << 2 )
#define evtParseMQTT ( 1 << 5 )
#define evtDoTheSunLampThing ( 1 << 10 )
int SunLampManual = 0; // manual on or off
int SunLampAuto = 1;// auto mode
int mqttOK = 0;
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient );
String str_eTopic;
char strPayload [300] = { '\0' };
SemaphoreHandle_t sema_MQTT_Parser; //if parsing is in progress hold up callback a moment to let parsing finish before sending a new things to parse
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
volatile bool TimeSet = false;
volatile int iDoTheThing = 0;
void IRAM_ATTR onTimer()
  BaseType_t xHigherPriorityTaskWoken;
  iDoTheThing++;
  if ( iDoTheThing == 60000 )
    xEventGroupSetBitsFromISR( eg, evtDoTheSunLampThing, &xHigherPriorityTaskWoken );
    iDoTheThing = 0;
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY); //if parsing is in progress hold up a moment to let parsing finish before sending a new things to parse
  str_eTopic = topic + '\0';
  int i = 0;
  for ( i; i < length; i++) {
    strPayload[i] = ((char)payload[i]);
  strPayload[i] = '\0';
  xSemaphoreGive ( sema_MQTT_Parser );
  xEventGroupSetBits( eg, evtParseMQTT ); // trigger tasks
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  gpio_config_t io_cfg = {};
  io_cfg.mode = GPIO_MODE_OUTPUT;
  //bit mask of the pins to set
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_15) );
  //  //configure GPIO with the given settings
  gpio_config(&io_cfg);
  REG_WRITE(GPIO_OUT_W1TC_REG, BIT15); // sunlamp
  /* Use 4th timer of 4.
    1 tick 1/(80MHZ/80) = 1us set divider 80 and count up.
    Attach onTimer function to timer
    Set alarm to call timer ISR, every 1000uS and repeat / reset ISR (true) after each alarm
    Start an timer alarm
  timer = timerBegin( 3, 80, true );
  timerAttachInterrupt( timer, &onTimer, true );
  timerAlarmWrite(timer, 1000, true);
  timerAlarmEnable(timer);
  str_eTopic.reserve(300);
  eg = xEventGroupCreate();
  sema_MQTT_Parser = xSemaphoreCreateBinary();
  sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 2, NULL, 1 ); //this task makes a WiFi and MQTT connection.
  xTaskCreatePinnedToCore( fDoTheSunLampThing, "fDoTheSunLampThing", 2000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 2000, NULL, 3, NULL, 1 );
} //setup() END
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 60;
  for (;;)
    vTaskDelay( 1000 );
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
    //log_i( "mqttOK %d", mqttOK );
  vTaskDelete( NULL );
void fDoTheSunLampThing( void * parameter )
  int _hour = rtc.getHour(true);
  // SunLampManual = sunlamp on manual mode, automatic mode off for manual mode to work
  // SunLampAuto = sun lamp enable automatic mode
  for (;;)
    xEventGroupWaitBits (eg, evtDoTheSunLampThing, pdTRUE, pdTRUE, portMAX_DELAY );
    // sun lamp auto mode of operation
    //log_i( "SunLampManualOnOff %d SunLampAuto %d",  SunLampManual, SunLampAuto  );
    if ( SunLampAuto )
      // run in automated mode
      _hour = rtc.getHour(true); // get hour in 24 hours format
      log_i( "get hour %d", _hour );
      if ( (_hour >= 7) && (_hour <= 19) )
        REG_WRITE(GPIO_OUT_W1TS_REG, BIT15);
      if ( (_hour < 7) || (_hour > 19) )
      // manual mode off/on
      if ( (SunLampManual == 1)  )
    //log_i( " AlreadyOn = %d", AlreadyOn );
    //log_i( "fDoTheSunLampThing high watermark %d",  uxTaskGetStackHighWaterMark( NULL ) );
} // void fDoTheSunLampThing( void * parameter )
    Important to not set vtaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
    makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
  vTaskDelete ( NULL );
void connectToMQTT()
  // create client ID from mac address
  byte mac[5];
  WiFi.macAddress(mac);
  log_i( "mac address %d.%d.%d.%d.%d", mac[0], mac[1], mac[2], mac[3], mac[4] );
  String clientID = String(mac[0]) + String(mac[4]) ;
  log_i( "connect to mqtt as client %s", clientID );
  while ( !MQTTclient.connected() )
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    log_i( "connecting to MQTT" );
    vTaskDelay( 250 );
  log_i("MQTT Connected");
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topic_SunLampOn );
  MQTTclient.subscribe( topic_SunLampEnable );
  MQTTclient.subscribe( topicOK );
void connectToWiFi()
  while ( WiFi.status() != WL_CONNECTED )
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
  WiFi.onEvent( WiFiEvent );
void fparseMQTT( void *pvParameters )
  for (;;)
    xEventGroupWaitBits ( eg, evtParseMQTT, pdTRUE, pdTRUE, portMAX_DELAY ); //
    xSemaphoreTake( sema_MQTT_Parser, portMAX_DELAY );
    if ( String(str_eTopic) == topic_SunLampOn )
      SunLampManual = String(strPayload).toInt();
      log_i( "SunLampManual on/off, %d", SunLampManual );
    if ( String(str_eTopic) == topic_SunLampEnable )
      SunLampAuto = String(strPayload).toInt();
      log_i( "sunlampAuto %d", SunLampAuto);
    // parse the time from the OK message and update MCU time
    if ( String(str_eTopic) == topicOK )
      if ( !TimeSet)
        String temp = "";
        temp = strPayload[0];
        temp += strPayload[1];
        temp += strPayload[2];
        temp += strPayload[3];
        int year =  temp.toInt();
        temp = "";
        temp = strPayload[5];
        temp += strPayload[6];
        int month =  temp.toInt();
        temp = "";
        temp = strPayload[8];
        temp += strPayload[9];
        int day =  temp.toInt();
        temp = "";
        temp = strPayload[11];
        temp += strPayload[12];
        int hour =  temp.toInt();
        temp = "";
        temp = strPayload[14];
        temp += strPayload[15];
        int min =  temp.toInt();
        rtc.setTime( 0, min, hour, day, month, year );
        log_i( "%s   rtc  %s ", strPayload, rtc.getTime() );
        TimeSet = true;
    // clear pointer locations
    memset( strPayload, '\0', 300 );
    str_eTopic = ""; //clear string buffer
    xSemaphoreGive( sema_MQTT_Parser );
    xEventGroupSetBits( eg, evtDoTheSunLampThing );
    mqttOK = 0;
} // void fparseMQTT( void *pvParameters )
// great trouble shooting tool when uncommented
void WiFiEvent(WiFiEvent_t event)
  // log_i( "[WiFi-event] event: %d\n", event );
  switch (event) {
    //    case SYSTEM_EVENT_WIFI_READY:
    //      log_i("WiFi interface ready");
    //      break;
    //    case SYSTEM_EVENT_SCAN_DONE:
    //      log_i("Completed scan for access points");
    //      break;
    //    case SYSTEM_EVENT_STA_START:
    //      log_i("WiFi client started");
    //      break;
    //    case SYSTEM_EVENT_STA_STOP:
    //      log_i("WiFi clients stopped");
    //      break;
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    //    case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
    //      log_i("Authentication mode of access point has changed");
    //      break;
    //    case SYSTEM_EVENT_STA_GOT_IP:
    //      log_i ("Obtained IP address: %s",  WiFi.localIP() );
    //      break;
    //    case SYSTEM_EVENT_STA_LOST_IP:
    //      log_i("Lost IP address and IP address is reset to 0");
    //      //      vTaskDelay( 5000 );
    //      //      ESP.restart();
    //      break;
    //    case SYSTEM_EVENT_STA_WPS_ER_SUCCESS:
    //      log_i("WiFi Protected Setup (WPS): succeeded in enrollee mode");
    //      break;
    //    case SYSTEM_EVENT_STA_WPS_ER_FAILED:
    //      log_i("WiFi Protected Setup (WPS): failed in enrollee mode");
    //      break;
    //    case SYSTEM_EVENT_STA_WPS_ER_TIMEOUT:
    //      log_i("WiFi Protected Setup (WPS): timeout in enrollee mode");
    //      break;
    //    case SYSTEM_EVENT_STA_WPS_ER_PIN:
    //      log_i("WiFi Protected Setup (WPS): pin code in enrollee mode");
    //      break;
    //    case SYSTEM_EVENT_AP_START:
    //      log_i("WiFi access point started");
    //      break;
    //    case SYSTEM_EVENT_AP_STOP:
    //      log_i("WiFi access point  stopped");
    //      //      WiFi.mode( WIFI_OFF);
    //      //      esp_sleep_enable_timer_wakeup( 1000000 * 2 ); // 1 second times how many seconds wanted
    //      //      esp_deep_sleep_start();
    //      break;
    //    case SYSTEM_EVENT_AP_STACONNECTED:
    //      log_i("Client connected");
    //      break;
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    //    case SYSTEM_EVENT_AP_STAIPASSIGNED:
    //      log_i("Assigned IP address to client");
    //      break;
    //    case SYSTEM_EVENT_AP_PROBEREQRECVED:
    //      log_i("Received probe request");
    //      break;
    //    case SYSTEM_EVENT_GOT_IP6:
    //      log_i("IPv6 is preferred");
    //      break;
    //    case SYSTEM_EVENT_ETH_GOT_IP:
    //      log_i("Obtained IP address");
    //      break;
    default: break;
void loop() { }
ESP32 conde that stays connected.
Thank you for the code.
Could you just check my code here, I am trying to send mulitple messages from Esp32 to MQTT broker(Raspberry Pi) but only one of the messages "EEG Sensor" is being published at the subscriber terminal, could you tell me what mistake I am doing here? I just want to see the two messages "EEG Sensor" and "EMG Sensor" printed on the command line of Raspberry Pi. Thank you.
Below is the code:
#define RXD2 16
#define TXD2 17
//char myRcvChar;
//WiFi
const char* ssid = "Bilal-Asad-310";
const char* wifi_password = "31019309";
//MQTT
const char* message1_topic = "test/esp32/message1";
const char* message2_topic = "test/esp32/message2";
const char* clientID = "client_esp32";
    Serial.print(".");
  else{
void setup(){
 //char myRcvchar;
  connect_MQTT();
  const char* message1 = "EEG Sensor";
  const char* message2 = "EMG Sensor";
  Serial.println("Message1 Received: ");
  Serial.println(message1);
  Serial.println("Message2 Received: ");
  Serial.println(message2);
  String ms1 = "Mess: "+String((char*)message1);
  String ms2 = "Mess: "+String((char*)message2);
  if(client.publish(message1_topic, String(message1).c_str())){
    Serial.println("Message1 sent");
  else{
    Serial.println("Message1 failed to send. Reconnecting to MQTT Broker and trying again");
    client.publish(message1_topic,String(message1).c_str());
  if(client.publish(message2_topic, String(message2).c_str())){
    Serial.println("Message2 sent");
  else{
    Serial.println("Message2 failed to send. Reconnecting to MQTT Broker and trying again");
    client.publish(message2_topic,String(message2).c_str());
  //client.disconnect(); //disconnect from the MQTT broker
  //delay(1000*60); //print new values every 1 minutes
  client.loop();
Check your code it seems a WiFi disconnect is never issued before a WiFi connect command is issued. This can cause the WiFi stack to corrupt. Put a WiFo disconnect before the connect so that you are not always connecting without a disconnect.
Alright.
And what about sending multiple messages like "EEG Sensor" and "EMG Sensor" as defined in my code to send them to MQTT broker? I just wants to know why the code is not reading the second if and else statement for the second message and also MQTT does not subscribes to the second message itself?
Thank you.
Post you new code that fixes the previous issue then we can move onto to other issues.
Hey where is the line of code
that registers the subscribed topic?
Hello,
I am following this example for the communication.
I tried the WiFi.disconnect(); before connect_MQTT(); but this does not sends any message to the broker at all. That's why I had to remove it but you can see where I defined it in my code.
The subscriber is the Raspberry Pi itself and that code is written exactly the same as the example shared above.
The code for Esp32:
#define RXD2 16
#define TXD2 17
//char myRcvChar;
//WiFi
//MQTT
    Serial.print(".");
  else{
  //WiFi.disconnect();
void setup(){
 //char myRcvchar;
  connect_MQTT();
  //Serial.println("Message1 Received: ");
  //Serial.println("Message2 Received: ");
  else{
  else{
  client.loop();
