Help me with Esp32-wroom-32. My ESP32 used to work properly... if i uploaded a code while it is connected to my laptop, it will immediately runs the code after the upload. But now, after successfully uploading a code, it will not run anything? unless i replug its data cable from esp32 to the usb port of my laptop
Even tried a simple led blinking but still has the same problem... doesnt work until replug the data cable
Thank you for your response. I was surprised by this issue, especially since I did not change any connections in the schematics or configurations in the IDE. It doesn't behave the same way as before. Previously, when I pressed the reboot button, the code would rerun. However, currently, if I press the reboot button, the program stops completely.
Yes i have tried it with other esp32
Hours before i encounter this problem, it works properly... upload and then i press the boot button to upload properly, then suddenly this thing happened
