Esp32 doubts regarding compilation error
#include <esp_now.h>
#include <WiFi.h>
#include "ESPAsyncWebServer.h"
#include <Arduino_JSON.h>
// Replace with your network credentials (STATION)
const char* ssid = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
// Structure example to receive data
// Must match the sender structure
typedef struct struct_message {
  int id;
  float temp;
  float hum;
  unsigned int readingId;
} struct_message;
struct_message incomingReadings;
JSONVar board;
AsyncWebServer server(80);
AsyncEventSource events("/events");
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *incomingData, int len) {
  // Copies the sender mac address to a string
  char macStr[18];
  Serial.print("Packet received from: ");
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.println(macStr);
  memcpy(&incomingReadings, incomingData, sizeof(incomingReadings));
  board["id"] = incomingReadings.id;
  board["temperature"] = incomingReadings.temp;
  board["humidity"] = incomingReadings.hum;
  board["readingId"] = String(incomingReadings.readingId);
  String jsonString = JSON.stringify(board);
  events.send(jsonString.c_str(), "new_readings", millis());
  Serial.printf("Board ID %u: %u bytes\n", incomingReadings.id, len);
  Serial.printf("t value: %4.2f \n", incomingReadings.temp);
  Serial.printf("h value: %4.2f \n", incomingReadings.hum);
  Serial.printf("readingID value: %d \n", incomingReadings.readingId);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <title>ESP-NOW DASHBOARD</title>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <link rel="icon" href="data:,">
  <style>
    html {font-family: Arial; display: inline-block; text-align: center;}
    p {  font-size: 1.2rem;}
    body {  margin: 0;}
    .topnav { overflow: hidden; background-color: #2f4468; color: white; font-size: 1.7rem; }
    .content { padding: 20px; }
    .card { background-color: white; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); }
    .cards { max-width: 700px; margin: 0 auto; display: grid; grid-gap: 2rem; grid-template-columns: repeat(auto-fit, minmax(300px, 1fr)); }
    .reading { font-size: 2.8rem; }
    .packet { color: #bebebe; }
    .card.temperature { color: #fd7e14; }
    .card.humidity { color: #1b78e2; }
  </style>
</head>
<body>
  <div class="topnav">
    <h3>ESP-NOW DASHBOARD</h3>
  </div>
  <div class="content">
    <div class="cards">
      <div class="card temperature">
        <h4><i class="fas fa-thermometer-half"></i> BOARD #1 - TEMPERATURE</h4><p><span class="reading"><span id="t1"></span> &deg;C</span></p><p class="packet">Reading ID: <span id="rt1"></span></p>
      </div>
      <div class="card humidity">
        <h4><i class="fas fa-tint"></i> BOARD #1 - HUMIDITY</h4><p><span class="reading"><span id="h1"></span> &percnt;</span></p><p class="packet">Reading ID: <span id="rh1"></span></p>
      </div>
        <h4><i class="fas fa-thermometer-half"></i> BOARD #2 - TEMPERATURE</h4><p><span class="reading"><span id="t2"></span> &deg;C</span></p><p class="packet">Reading ID: <span id="rt2"></span></p>
      </div>
        <h4><i class="fas fa-tint"></i> BOARD #2 - HUMIDITY</h4><p><span class="reading"><span id="h2"></span> &percnt;</span></p><p class="packet">Reading ID: <span id="rh2"></span></p>
      </div>
    </div>
  </div>
<script>
if (!!window.EventSource) {
 var source = new EventSource('/events');
 source.addEventListener('open', function(e) {
  console.log("Events Connected");
 }, false);
 source.addEventListener('error', function(e) {
  if (e.target.readyState != EventSource.OPEN) {
    console.log("Events Disconnected");
 }, false);
 source.addEventListener('message', function(e) {
  console.log("message", e.data);
 }, false);
 source.addEventListener('new_readings', function(e) {
  console.log("new_readings", e.data);
  var obj = JSON.parse(e.data);
  document.getElementById("t"+obj.id).innerHTML = obj.temperature.toFixed(2);
  document.getElementById("h"+obj.id).innerHTML = obj.humidity.toFixed(2);
  document.getElementById("rt"+obj.id).innerHTML = obj.readingId;
  document.getElementById("rh"+obj.id).innerHTML = obj.readingId;
 }, false);
</script>
</body>
</html>)rawliteral";
  // Initialize Serial Monitor
  // Set the device as a Station and Soft Access Point simultaneously
  WiFi.mode(WIFI_AP_STA);
  // Set device as a Wi-Fi Station
  WiFi.begin(ssid, password);
    Serial.println("Setting as a Wi-Fi Station..");
  Serial.print("Station IP Address: ");
  Serial.print("Wi-Fi Channel: ");
  Serial.println(WiFi.channel());
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(OnDataRecv);
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html);
  events.onConnect([](AsyncEventSourceClient *client){
    if(client->lastId()){
      Serial.printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId());
    // send event with message "hello!", id current millis
    // and set reconnect delay to 1 second
    client->send("hello!", NULL, millis(), 10000);
  server.addHandler(&events);
  server.begin();
  static unsigned long lastEventTime = millis();
  static const unsigned long EVENT_INTERVAL_MS = 5000;
  if ((millis() - lastEventTime) > EVENT_INTERVAL_MS) {
    events.send("ping",NULL,millis());
I am getting the following error:
Compilation error: invalid conversion from 'void ()(const uint8_t, const uint8_t*, int)' {aka 'void ()(const unsigned char, const unsigned char*, int)'} to 'esp_now_recv_cb_t' {aka 'void ()(const esp_now_recv_info, const unsigned char*, int)'} [-fpermissive]
What is wrong with my code? Please help!
You should post the error messages as code, because sometimes they have symbols that end up formatting your message, like asterisks making things italic:
void (*)(const uint8_t*, const uint8_t*, int)
becomes
You are using version 5 of ESP-IDF, where esp_now_recv_cb_t expects a esp_now_recv_info_t as the first argument; perhaps because you recently upgraded to version 3 of Arduino-ESP32. Your OnDataRecv targets the older IDF version 4, where the first argument is const uint8_t * as the MAC address, just like you have it in your code.
You'll have to change the function signature to match, and get the sender/source MAC from the new struct argument.
This is the error:
You did not use <CODE/> in the toolbar when posting.
At a glance, the paragraph in your post #4 above, with all the italic text, looks identical to the one in your original post #1.
Regardless, the explanation in post #2 still stands, and says what to do. Is there something you don't understand about it?
Compiles fine here with IDE 1.8.19.
Make sure your board files and libraries are all up to date.
Leo..
The problem is due to blindly/obediently updating the Board platform, which in this case was a major version from v2 to v3, including breaking changes. A bunch of online tutorials are now out-of-date and will no longer compile.
for Arduino core V3.0 try changing the function header to
void OnDataRecv(const esp_now_recv_info* mac_addr, const uint8_t *incomingData, int len) {
have a look at migration_guides/2.x_to_3.0
I think @kenb4 made a point here.
Just upgraded the ESP32 board files from v2.0.14 to v3.0.1
and now the sketch has that compile error.
Leo..
Edit: A sketch that I had with WiFiManager compiled, but WiFi stopped working after upgrading to v3.
