ESP32 Draws Graphics on ILI9341 ESP8266 Does Not
I have a very simple ESP32 sketch which draws a straight yellow line on a blue screen on an ILI9341 TFT display. I have an identical sketch written for an ESP8266 which uploads OK but does not draw the line on the same ILI9341 TFT display.
I believe the problem is caused by the USB drivers I use for each uProcessor.
For the ESP32:
// # Microprocessor: ESP32 Dev Module
// # Display: Display: MSP2807 TFT LCD, 240 x 320 Pixels
// # Control IC: ILI9341
// # Device Driver: SILICON LABS CP210x USB to UART Bridge (COM4)
// # Needs Font 2 (also Font 4 if using large scale label)
// # Comm Port: COM4
#include <SPI.h>
#include <Adafruit_GFX.h>       // include Adafruit graphics library
#include <Adafruit_ILI9341.h>   // include Adafruit ILI9341 TFT library
// # We need six connections to drive the PDI035HVHI-48
// # ILI9488 TFT display from the ESP32 uProcessor
// # Define pin connections between display and the ESP32 uP
#define TFT_CS    15  // TFT CS  Pin 3 conn to ESP32 uP pin 15  Brown
#define TFT_RST   4   // TFT RST Pin 4 conn to ESP32 uP pin  4  Red
#define TFT_DC    2   // TFT DC  Pin 5 conn to ESP32 uP pin  2  Orange
// # Other pin connections between display and the ESP32 uP shown below
   #define TFT_MOSI   23  // TFT MOSI Pin 6 conn to ESP32 uP pin 23  Yellow
   #define TFT_SCK    18  // TFT SCK  Pin 7 conn to ESP32 uP pin 18  Green
   #define TFT_MISO   21  // TFT MISO Pin 9 conn to ESP32 uP pin 21  Gray
// #define TFT_LED 3.3V // TFT LED conn to ESP32 uP pin 3.3V
// initialize ILI9341 TFT library
  Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
// # Define constants used in this sketch
float Yi= 20, Yf= 150, del1=1;
float X_Beg=10, X_End=479-X_Beg, Y_Beg=Yf, Y_End=Yf;
tft.begin();
tft.setRotation(3);
tft.fillScreen(ILI9341_BLUE);
tft.setTextSize(3);
tft.setCursor(X_Beg, Y_Beg);
tft.drawLine(X_Beg, Y_Beg, X_End, Y_End, ILI9341_YELLOW);
void loop(){}
Wiring Diagram:
ESP32 Line Draw.pdf (75.0 KB)
The driver files from the Device Manager for this ESP32 sketch are:
ESP32 Device Manager Driver Contents.pdf (102.5 KB)
This ESP32 sketch uploads and plots the straight line on the ILI9341 TFT screen.
For the ESP8266:
// # Microprocessor: ESP8266 Dev Module
// # Device Driver: USB-SERIAL CH340 (COM3)
// # Comm Port: COM3 Driven by CH340 driver
#include <SPI.h>
// # ILI9488 TFT display from the ESP8266 uProcessor
// # Define pin connections between display and the ESP8266 uP
#define TFT_CS 8 // TFT CS Pin 3 conn to ESP8266 uP pin 8 Brown
#define TFT_RST 4 // TFT RST Pin 4 conn to ESP8266 uP pin 4 Red
#define TFT_DC 3 // TFT DC Pin 5 conn to ESP8266 uP pin 3 Orange
// # Other pin connections between display and the ESP8266 uP shown below
    #define TFT_MOSI  7  // TFT MOSI Pin 6 conn to ESP8266 uP pin 7  Yellow
    #define TFT_SCK   5  // TFT SCK  Pin 7 conn to ESP8266 uP pin 5  Green
    #define TFT_MISO  6  // TFT MISO Pin 9 conn to ESP8266 uP pin 6  Gray
// #define TFT_LED 3.3V // TFT LED conn to ESP8266 uP pin 3.3V
tft.begin();
tft.setRotation(3);
tft.setTextSize(3);
void loop(){}
ESP8266 Wiring Diagram:
ESP8266 Line Draw.pdf (67.9 KB)
The driver files from the Device Manager for this ESP8266 sketch are:
ESP8266 Device Manager Driver Contents.pdf (104.3 KB)
What is the problem with the ESP8266 sketch?
Is it the driver that I am using?
