ESP32-E Array doesn't contain initialised values
I have a large program I'm working on for a FIREBEETLE ESP32-E with a 2-dimensional array declared and initiated globally at the top of the code. when I accessed the array the code didn't function as expected, I printed the values to console and the contents was garbage.
So I created a simple sketch below with a single dimension array to try to see where I was going wrong....but the problem persisted in this simple sketch?!?!?
int times[] =  {0,130,255,255};
  Serial.println("Array Test");
  times[0] =  0; // I added to see if setting a value here made a difference
  int one = times[0];
  int two = times[1];
  Serial.print("Direct access to 1st Value is: ");
  Serial.println(times[0],DEC);
  Serial.print("Direct access to 2nd Value is:");
  Serial.println(times[1],DEC);
  Serial.print("accessing int one: ");
  Serial.println(one);
  Serial.print("accessing int two ");
  Serial.println(two);
  delay(2000);
The code in the main loop prints this to console:
Direct access to 1st Value is: 620773686
Direct access to 2nd Value is:-1306523032
accessing int one: 620773686
accessing int two -1306523032
It doesn't seem to matter where I try setting array values, they always come back wrong.
If I declare the array as being length 4, that doesn't help.
if I declare the array as "const int" then the value are correct, but this doesn't help me as I need to change the values.
If I try running this same simple sketch on a Arduino 33 IOT then the code works fine resulting in the expected values printed to console:
Direct access to 1st Value is: 0
Direct access to 2nd Value is: 130
accessing int one: 0
accessing int two 130
Am I missing something(pretty sure that I am), or could this be a board library bug?
Hopefully someone can help point me in the right direction.
It works as expected if you name the array something besides "times". Can't tell you why.
Well cover me in bowls of food and call me a Lazy Susan!
That's absurd!
Thanks for the assistance!
