ESP32 + ECC508A issue
I'm using an ESP32-WROOM-32D connected to an ECC508A via SDA and SCL. Both have 4.7k resistors.
Libraries used:
#include <ArduinoECCX08.h>
#include <utility/ECCX08SelfSignedCert.h>
#include <utility/ECCX08DefaultTLSConfig.h>
#include <EEPROM.h>
#include "CRC32.h"
on the ESP32 EEPROM i write the input, signature and public key.
On the ECC508A, slot 0, I store the private key.
Everything writes just fine to the esp32 eeprom and I'm assuming the ECC508A. I can dump the input, sig and pub key from EEPROM on the esp32 fine. Then I get this error below when I run :
ECCX08.ecdsaVerify(settings.input, settings.signature, settings.public_key)
Error is:
[ 2188][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263
[ 4189][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263 ..... etc etc.
It supposedly does communicate with the the ECC508A:
    Attempting to communicate with ECC508/ECC608...
    Successfully established communication with ECC508/ECC608.
I've tried to add Wire.settimeout(2000); to see if it helps but it doesnt. I'm totally stumped.
Post complete code!
Error 263 means that the request timed out. Ensure the connection between the two boards is stable and all wires are OK!
I guess (or hope) there are missing some connection (GND, VCC). Post a link to the breakout board you used!
its a custom PCB. I'll take a look at the gerber files.
Post the schematics!
Yea not going to do that. What I am going to do is put the ecc508a on its own pcb with some dupont style connectors that way I can test the library. If that works (because its basically the same thing), then I'll know its my custom PCB that has the issue somewhere.
Wire.setBufferSize(256);
fixed it.
