I am using asyncwebserver to change settings in preferences.
I can enter text and click submit to change settings in the nvram.
I want to set ip, subnet mask and gateway but there is nothing to stop the entering of illegal information ie 192.168.10.1 is legal but a.b.c.d should be illegal entry.
255.255.255.0 is legal but 0.255.255.255 is illegal.
Are there any examples of running rule checks for these?
I can now validate the ip subnet and gateway but only as far as numbers between 0 an 255 using the following but was hoping someone already created a library for doing the entire task.
void handleIPAddress(AsyncWebServerRequest *request) {
String ipAddress = request->getParam("ip_address")->value();
// Validate the IP address
if (!validateIPAddress(ipAddress)) {
request->send(400, "Bad Request", "Invalid IP address");
return;
// Process the IP address
Serial.println("IP address: " + ipAddress);
request->send(200, "OK", "IP address accepted");
bool validateIPAddress(String ipAddress) {
// Split the IP address into four sections
String sections[4];
ipAddress.split(".", sections, 4);
// Check if the IP address has four sections
if (sections.length != 4) {
return false;
// Check if each section is a valid number
for (int i = 0; i < 4; i++) {
int section = sections[i].toInt();
if (section < 0 || section > 255) {
return false;
return true;
server.on("/ip_address", handleIPAddress);
server.begin();
