Hi everyone
I'm trying to transmit sensor data from an MPU6050 accelerometer/gyroscope hooked up to an Adafruit HUZZAH32 – ESP32 Feather. I am using the board as a WiFi Access Point and want to send the data to my laptop.
I've managed to set up the access point and read out the sensor data, however, I get an error message when I try to send the data via UDP.
This is the error message I'm getting: > cannot bind non-const lvalue reference of type 'AsyncUDPMessage&' to an rvalue of type 'AsyncUDPMessage'
It appears to have to do with the way the Adafruit Unified Sensor driver references the data obtained from the sensor as a pointer instead of a variable, but I admit that I can't get my head around what's happening exactly and how and why they are used here (source).
Essentially, my question is twofold:
- Could anyone explain these two lines of code for me?
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
sensors_event_t is a data structure specific for the Adafruit Unified Sensors driver, but I don't quite understand technically what is exactly stored and why '&' is used here.
- How can I convert sensor data to a format I can send via UDP so that it doesn't throw me the above error message?
any help is much appreciated! best wishes -.-
here's my sketch in full:
// the purpose of this sketch is to send actual measurement data over wifi
#include "WiFi.h" // include libraries
#include "AsyncUDP.h"
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
const char* ssid = "ESP32_AP";
const char* password = NULL; // set password, NULL; sets no password
AsyncUDP udp;
Serial.begin(115200); // start serial connection
/* initialize wifi Access Point */
Serial.println("\n[*] Creating AP"); // print
WiFi.mode(WIFI_AP); // ESP32 wifi in Access Point (AP) mode (as opposed to connecting to an existing wifi via router)
WiFi.softAP(ssid, password); // set AP name & password
Serial.print("[+] AP Created with IP Gateway "); // print
Serial.println(WiFi.softAPIP()); // print IO host: 192.168.4.1 [client: 192.168.4.2]
/* setup listening for incoming packets */
if (udp.listen(1234)) { // listen on port 1234
Serial.print("UDP Listening on IP: "); // print
Serial.println(WiFi.localIP()); // print local AP host IP (always 192.168.4.1.)
udp.onPacket([](AsyncUDPPacket packet) { // ???
Serial.print("UDP Packet Type: ");
Serial.print(packet.isBroadcast() ? "Broadcast" : packet.isMulticast() ? "Multicast" : "Unicast");
Serial.print(", From: ");
Serial.print(packet.remoteIP());
Serial.print(":");
Serial.print(packet.remotePort());
Serial.print(", To: ");
Serial.print(packet.localIP());
Serial.print(":");
Serial.print(packet.localPort());
Serial.print(", Length: ");
Serial.print(packet.length());
Serial.print(", Data: ");
Serial.write(packet.data(), packet.length());
packet.printf("Got %u bytes of data", packet.length()); // reply to the client
/* setup MPU6050 sensor */
Serial.println("Adafruit MPU6050 test!"); // print
/* Try to initialize! */
if (!mpu.begin()) { // if .begin function returns false ... (= "Logical NOT results in a true if the operand is false and vice versa.")
Serial.println("Failed to find MPU6050 chip"); // ... print failure message ...
while (1) { // ... & create an endless loop to stop the program from doing anything useful. can only be reset manually via the 'reset' button
delay(100); // orig.: 10ms
Serial.println("MPU6050 init failure loop"); // little debug print loop to see where it stopped
Serial.println("MPU6050 Found!"); // if not, proceed as planned
/* set accelerometer range */
mpu.setAccelerometerRange(MPU6050_RANGE_8_G); // set the range of the accelerometer (a smaller range produces a more sensitive outcome) for sensor "mpu" which was defined above
Serial.print("Accelerometer range set to: "); // print
switch (mpu.getAccelerometerRange()) { // switch...case = if...then -> get function returns range that was set above
case MPU6050_RANGE_2_G:
Serial.println("+-2G"); // print currently set range
case MPU6050_RANGE_4_G:
Serial.println("+-4G");
case MPU6050_RANGE_8_G:
Serial.println("+-8G");
case MPU6050_RANGE_16_G:
Serial.println("+-16G");
/* set gyroscope range */
mpu.setGyroRange(MPU6050_RANGE_500_DEG); // setting the gyroscope range in degrees/s. To get a more sensitive output response, set smaller degrees per second for the gyroscope range.
Serial.print("Gyro range set to: ");
switch (mpu.getGyroRange()) {
case MPU6050_RANGE_250_DEG:
Serial.println("+- 250 deg/s");
case MPU6050_RANGE_500_DEG:
Serial.println("+- 500 deg/s");
case MPU6050_RANGE_1000_DEG:
Serial.println("+- 1000 deg/s");
case MPU6050_RANGE_2000_DEG:
Serial.println("+- 2000 deg/s");
/* set filter bandwidth */
mpu.setFilterBandwidth(MPU6050_BAND_21_HZ); // this is done to ensure all the unnecessary frequencies are filtered out and a smoother, cleaner output is obtained.
Serial.print("Filter bandwidth set to: ");
switch (mpu.getFilterBandwidth()) {
case MPU6050_BAND_260_HZ:
Serial.println("260 Hz");
case MPU6050_BAND_184_HZ:
Serial.println("184 Hz");
case MPU6050_BAND_94_HZ:
Serial.println("94 Hz");
case MPU6050_BAND_44_HZ:
Serial.println("44 Hz");
case MPU6050_BAND_21_HZ:
Serial.println("21 Hz");
case MPU6050_BAND_10_HZ:
Serial.println("10 Hz");
case MPU6050_BAND_5_HZ:
Serial.println("5 Hz");
Serial.println(""); // print
delay(100); // small delay
/* Get new sensor events with the readings, see https://learn.adafruit.com/using-the-adafruit-unified-sensor-driver?view=all */
/* Print out the values */
Serial.print("Acceleration X: ");
Serial.print(a.acceleration.x);
udp.broadcastTo(a.acceleration.x, 8000);
Serial.print(", Y: ");
Serial.print(a.acceleration.y);
//udp.broadcastTo(a.acceleration.y, 8000);
Serial.print(", Z: ");
Serial.print(a.acceleration.z);
//udp.broadcastTo(a.acceleration.z, 8000);
Serial.println(" m/s^2");
Serial.print("Rotation X: ");
Serial.print(g.gyro.x);
//udp.broadcastTo(g.gyro.x, 8000);
Serial.print(g.gyro.y);
//udp.broadcastTo(g.gyro.y, 8000);
Serial.print(g.gyro.z);
//udp.broadcastTo(g.gyro.z, 8000);
Serial.println(" rad/s");
// Serial.print("Temperature: ");
// Serial.print(temp.temperature);
// Serial.println(" degC");
Serial.println("");
