Hello, I just installed Arduino IDE for Windows 7 and newer (using windows 10). I installed support for the ESP32, selected DOIT ESP32 DEVKIT V1 and selected the ESP32 BLE Arduino EXAMPLE: BLE_write. It compiled the first time but when I went to upload I got an error:
Error compiling for board DOIT ESP32 DEVKIT V1
Can you help me figure out what is going wrong?
When I push, Copy error messages, I get:
Arduino: 1.8.19 (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\e729128\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\e729128\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\e729128\OneDrive - Honeywell\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\e729128\AppData\Local\Temp\arduino_build_744136 -warnings=none -build-cache C:\Users\e729128\AppData\Local\Temp\arduino_cache_950042 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -verbose C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\BLE_write.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\e729128\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\e729128\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\e729128\OneDrive - Honeywell\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32doit-devkit-v1:FlashFreq=80,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\e729128\AppData\Local\Temp\arduino_build_744136 -warnings=none -build-cache C:\Users\e729128\AppData\Local\Temp\arduino_cache_950042 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.3.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -verbose C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\BLE_write.ino
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
Using core 'esp32' from platform in folder: C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
cmd /c if exist "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\partitions.csv" COPY /y "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\partitions.csv" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\partitions.csv"
cmd /c if not exist "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\partitions.csv" if exist "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\doitESP32devkitV1\partitions.csv" COPY "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\doitESP32devkitV1\partitions.csv" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\partitions.csv"
cmd /c if not exist "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\partitions.csv" COPY "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\partitions\default.csv" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\partitions.csv"
cmd /c IF EXIST "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\bootloader.bin" ( COPY /y "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\bootloader.bin" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\BLE_write.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\doitESP32devkitV1\bootloader.bin" ( COPY "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\doitESP32devkitV1\bootloader.bin" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\BLE_write.ino.bootloader.bin" ) ELSE ( COPY /y "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\sdk\esp32\bin\bootloader_dio_80m.bin" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\BLE_write.ino.bootloader.bin" ) )
1 file(s) copied.
cmd /c if exist "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\build_opt.h" COPY /y "C:\Users\e729128\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\BLE\examples\BLE_write\build_opt.h" "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\build_opt.h"
cmd /c if not exist "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\build_opt.h" type nul > "C:\Users\e729128\AppData\Local\Temp\arduino_build_744136\build_opt.h"
Detecting libraries used...
Error compiling for board DOIT ESP32 DEVKIT V1.
