ESP32 FastLED show() shift
Hello :slight_smile:,
I'm using FastLED on ESP32 to control 4 LEDs strips, 1 task running 1 strip.
After a while I get data shift on a single or multiple strip.
For exemple I ask LED 4 on strip 1 to turn on, nothing happen. When I ask an other LED on any strip to turn on, LED 4 on strip 1 turn on but not the asked LED, and so on.
It happens randomly and I'm sure to set the right LED with the right color (I put a print on it).
What could it be ?
Thank you for any help.
Here a smaller version of the code :slight_smile:
#include "StripBox.h"
#include <Arduino.h>
#include <FastLED.h>
CRGB StripBox::s_Strips[4][NUM_LEDS];
StripBox::StripBox(uint8_t stripNum)
    m_StripNum = stripNum;
    queueStrip = xQueueCreate(MAX_STRIP_QUEUE_LENGHT, sizeof(int[STRIP_MSG_LENGTH]));
    switch (stripNum)
    case 0:
        FastLED.addLeds<NEOPIXEL, STIP_0_PIN>(s_Strips[0], NUM_LEDS);
    case 1:
        FastLED.addLeds<NEOPIXEL, STIP_1_PIN>(s_Strips[1], NUM_LEDS);
    case 2:
        FastLED.addLeds<NEOPIXEL, STIP_2_PIN>(s_Strips[2], NUM_LEDS);
    case 3:
        FastLED.addLeds<NEOPIXEL, STIP_3_PIN>(s_Strips[3], NUM_LEDS);
    default:
        Serial.println("[StripBox::StripBox] Strip index out of bounds");
void StripBox::startLoop()
    xTaskCreatePinnedToCore(
        this->s_LoopCall,
        "LED",
        1480,
        (void *)this,
        1,
        &taskHandle,
        1);
void StripBox::s_LoopCall(void *_this)
    StripBox c = *((StripBox *)_this);
    c.loop();
void StripBox::controlLEDProcess(int data[STRIP_MSG_LENGTH])
    CRGB color = CRGB(data[3], data[4], data[5]);
    controlLED(data[2], color);
void StripBox::controlLED(uint8_t ledIndex, CRGB color)
    s_Strips[m_StripNum][ledIndex] = color;
void StripBox::addToDataQueue(int data[STRIP_MSG_LENGTH])
    xQueueSend(queueStrip, data, 1000);
void StripBox::loop()
    for (;;)
        std::fill_n(m_Data, STRIP_MSG_LENGTH, INT_MAX);
        xQueueReceive(queueStrip, &m_Data, queueDelay);
        controlLEDProcess(m_Data);
        vTaskDelay(1 / portTICK_PERIOD_MS);
        FastLED.show();
        vTaskDelay(delay / portTICK_PERIOD_MS);
Don't post snippets (Snippets R Us!)
what about the .h and the main code?
can't do much with that
There was another discussion regarding the ESP-implementation of FastLED. A solution wasn't found.
I have used the Adafruit neopixel library and haven't run into any ESP anomalies.
You do ofcourse have a level shifter between the 3.3volt-logic of the ESP and 5volt-logic of the LEDs.
Without that you can't be sure if the problem is in the code.
Leo..
Thank you for your help. I'm sorry but I can't put all the code.
I'll try the Neopixel solution. I don't thinks it's related to the 5V (I have level shifter).
I'll let you know if it work.
Hello,
It seems that I was not using the latest version of FastLED. I updated and it seems to be fixed. It is well marked that the update greatly improves compatibility with the ESP32.
Which seems to be true.
