kompilieren lässt es sich ja, hochladen nicht da kommt auch eine Fehlermeldung:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kjell\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kjell\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kjell\OneDrive\Dokumente\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\kjell\AppData\Local\Temp\arduino_build_659656 -warnings=none -build-cache C:\Users\kjell\AppData\Local\Temp\arduino_cache_753750 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.mklittlefs.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.mkspiffs.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -verbose C:\Users\kjell\AppData\Local\Temp\arduino_modified_sketch_661064\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kjell\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kjell\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kjell\OneDrive\Dokumente\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path C:\Users\kjell\AppData\Local\Temp\arduino_build_659656 -warnings=none -build-cache C:\Users\kjell\AppData\Local\Temp\arduino_cache_753750 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.mklittlefs.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.openocd-esp32.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.mkspiffs.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -verbose C:\Users\kjell\AppData\Local\Temp\arduino_modified_sketch_661064\Blink.ino
Using board 'esp32' from platform in folder: C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9
Using core 'esp32' from platform in folder: C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9
cmd /c if exist "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\partitions.csv" COPY /y "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\partitions.csv" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\partitions.csv"
cmd /c if not exist "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\partitions.csv" if exist "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\partitions.csv" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\partitions.csv"
cmd /c if not exist "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\partitions.csv" COPY "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\tools\\partitions\\default.csv" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\bootloader.bin" ( COPY /y "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\bootloader.bin" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\Blink.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32\\bootloader.bin" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\Blink.ino.bootloader.bin" ) ELSE ( "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\Blink.ino.bootloader.bin" "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\build_opt.h" COPY /y "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\build_opt.h" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\build_opt.h"
cmd /c if not exist "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\build_opt.h" type nul > "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\build_opt.h"
Detecting libraries used...
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.4\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/log/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/console" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/build_opt.h" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\cores\\esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.4\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/log/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/console" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/build_opt.h" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\cores\\esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\sketch\\Blink.ino.cpp" -o "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.4\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/log/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/console" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/src/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/build_opt.h" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\cores\\esp32" "-IC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\variants\\esp32" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\sketch\\Blink.ino.cpp" -o "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\kjell\AppData\Local\Temp\arduino_cache_753750\core\core_e1715f1998771708b48ea0c4382551ce.a
Linking everything together...
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/Blink.ino.map" "-LC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/lib" "-LC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/ld" "-LC:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/sdk/esp32/qio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\sketch\\Blink.ino.cpp.o" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_cache_753750\\core\\core_e1715f1998771708b48ea0c4382551ce.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -lesp_diagnostics -lrtc_store -lesp_insights -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp-sr -lesp32-camera -lesp_littlefs -lespressif__esp-dsp -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lesp_insights -lcbor -lesp_diagnostics -lrtc_store -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lqrcode -lrmaker_common -lmqtt -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -lesp-sr -lmultinet -lesp_audio_processor -lesp_audio_front_end -lwakenet -ljson -lspiffs -ldl_lib -lc_speech_features -lwakeword_model -lmultinet2_ch -lesp_tts_chinese -lvoice_set_xiaole -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/Blink.ino.elf"
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/Blink.ino.bin" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/Blink.ino.elf"
esptool.py v4.5.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/gen_esp32part.exe" -q "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/partitions.csv" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/Blink.ino.partitions.bin"
cmd /c if exist "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656\\libraries\\Insights" "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9/tools/gen_insights_package.exe" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656" Blink.ino "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064"
cmd /c IF 0==1 COPY /y "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\openocd-esp32\\v0.11.0-esp32-20221026\\share\\openocd\\scripts\\board\\esp32-wrover-kit-3.3v.cfg" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\debug.cfg"
cmd /c IF 0==1 COPY /y "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\tools\\ide-debug\\esp32.json" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\debug_custom.json"
cmd /c IF 0==1 COPY /y "C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.9\\tools\\ide-debug\\svd\\esp32.svd" "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_modified_sketch_661064\\debug.svd"
"C:\\Users\\kjell\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-size" -A "C:\\Users\\kjell\\AppData\\Local\\Temp\\arduino_build_659656/Blink.ino.elf"
Der Sketch verwendet 235897 Bytes (17%) des Programmspeicherplatzes. Das Maximum sind 1310720 Bytes.
Globale Variablen verwenden 22056 Bytes (6%) des dynamischen Speichers, 305624 Bytes für lokale Variablen verbleiben. Das Maximum sind 327680 Bytes.
C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1/esptool.exe --chip esp32 --port COM4 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 C:\Users\kjell\AppData\Local\Temp\arduino_build_659656/Blink.ino.bootloader.bin 0x8000 C:\Users\kjell\AppData\Local\Temp\arduino_build_659656/Blink.ino.partitions.bin 0xe000 C:\Users\kjell\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9/tools/partitions/boot_app0.bin 0x10000 C:\Users\kjell\AppData\Local\Temp\arduino_build_659656/Blink.ino.bin
esptool.py v4.5.1
Serial port COM4
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x13)! The chip needs to be in download mode.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Der ausgewählte serielle Port For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
ist nicht vorhanden oder das Board ist nicht angeschlossen
