Ich kann AVR Bords und ESP8266 Boards problemlos kompillieren.
Ich schaffe es aber nicht mit einem ESP32 Board. Weder mit der IDE 2.0.1 noch mit 1.8.18 und egal welches Board.
Ich bekomme folgenden Fehler:
Arduino: 1.8.18 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
Hier noch mein Code:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\werni\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\werni\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\werni\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10818 -build-path C:\Users\werni\AppData\Local\Temp\arduino_build_663093 -warnings=default -build-cache C:\Users\werni\AppData\Local\Temp\arduino_cache_865902 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -verbose C:\Users\werni\AppData\Local\Temp\untitled66852871.tmp\sketch_nov14a\sketch_nov14a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\werni\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\werni\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\werni\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none -ide-version=10818 -build-path C:\Users\werni\AppData\Local\Temp\arduino_build_663093 -warnings=default -build-cache C:\Users\werni\AppData\Local\Temp\arduino_cache_865902 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mklittlefs.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\werni\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -verbose C:\Users\werni\AppData\Local\Temp\untitled66852871.tmp\sketch_nov14a\sketch_nov14a.ino
Using board 'esp32' from platform in folder: C:\Users\werni\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
Using core 'esp32' from platform in folder: C:\Users\werni\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
cmd /c if exist "C:\Users\werni\AppData\Local\Temp\untitled66852871.tmp\sketch_nov14a\partitions.csv" COPY /y "C:\Users\werni\AppData\Local\Temp\untitled66852871.tmp\sketch_nov14a\partitions.csv" "C:\Users\werni\AppData\Local\Temp\arduino_build_663093\partitions.csv"
Das System kann den angegebenen Pfad nicht finden.
exit status 1
Error compiling for board ESP32 Dev Module.
exit status 1
Auffallend ist, dass die Zeile mit:
cmd /c if exist "C:\Users\werni\AppData\Local\Temp\untitled1815332539.tmp\sketch_nov10a\partitions.csv" COPY /y "C:\Us...
jeweils doppelte \ hat. Ich könnte mir vorstellen, dass es daran liegt, dass er den Pfad nicht findet.
Weiss jemand, woher das kommt? Oder noch besser, wie ich das beheben kann?
Besten Dank Werni
