Hello, I'm trying to download an image with an HTTP request and send the image data to eink display. The eink display I'm using is Waveshare 7.5inch eink display. Each pixel in the display is represented by a single bit (1 for black and 0 for white). The display seems to expect unsigned char array where each element represents 8 pixels. I have been googling online and asking ChatGPT but I have not been able to figure out how to download the data correctly and send to the display. Can someone please help with this?
#include "DEV_Config.h"
#include "EPD.h"
#include "GUI_Paint.h"
#include "imagedata.h"
#include <stdlib.h>
#include <WiFi.h>
#include <HTTPClient.h>
#include <SPIFFS.h>
const char* ssid = "";
const char* password = "";
const char* imageUrl = "https://fastly.picsum.photos/id/538/800/480.jpg?grayscale&hmac=z6A6OaRs-W_K6IOv7ghUPDw70SlLDtjilwctBN4FmqA";
// const int imageWidth = 800;
// const int imageHeight = 480;
// const size_t imageSize = imageWidth * imageHeight * 3; // Assuming RGB format
// unsigned char imageBuffer[imageSize];
WiFi.begin(ssid, password);
Serial.println("WiFi - Connecting......");
Serial.println("WiFi - Connected");
if(!SPIFFS.begin()){
Serial.println("An Error has occurred while mounting SPIFFS");
return;
printf("EPD_7IN5_V2_test Demo\r\n");
DEV_Module_Init();
printf("e-Paper Init and Clear...\r\n");
EPD_7IN5_V2_Init();
EPD_7IN5_V2_Clear();
DEV_Delay_ms(500);
UBYTE *BlankImage;
UWORD Imagesize = ((EPD_7IN5_V2_WIDTH % 8 == 0) ? (EPD_7IN5_V2_WIDTH / 8 ) : (EPD_7IN5_V2_WIDTH / 8 + 1)) * EPD_7IN5_V2_HEIGHT;
if ((BlankImage = (UBYTE *)malloc(Imagesize)) == NULL) {
printf("Failed to apply for black memory...\r\n");
while (1);
printf("Paint_NewImage\r\n");
Paint_NewImage(BlankImage, EPD_7IN5_V2_WIDTH, EPD_7IN5_V2_HEIGHT, 0, WHITE);
// #if 1 // show image for array
// printf("show image for array\r\n");
// Paint_SelectImage(BlankImage);
// Paint_Clear(WHITE);
// Paint_DrawBitMap(testImage);
// EPD_7IN5_V2_Display(BlankImage);
// DEV_Delay_ms(1000);
// #endif
#if 1
HTTPClient http;
http.begin(imageUrl);
int httpCode = http.GET();
if (httpCode <= 0) {
Serial.print("Failed to fetch the JPEG image, HTTP code: ");
Serial.println(httpCode);
return;
// Serial.printf(http.header("Content-Type"));
String length = http.header("Content-Length");
Serial.printf("length", length);
WiFiClient* stream = http.getStreamPtr();
File file = SPIFFS.open("/image.png", FILE_WRITE);
while (http.connected() && stream->available()) {
file.write(stream->read());
size_t fileSize = file.size();
Serial.printf("file size", fileSize);
file.read(BlankImage, fileSize);
file.close();
Paint_Clear(WHITE);
Paint_DrawBitMap(BlankImage);
DEV_Delay_ms(1000);
http.end();
#endif
printf("Goto Sleep...\r\n");
EPD_7IN5_V2_Sleep();
free(BlankImage);
BlankImage = NULL;
It looks like the way the display library works is first you call Paint_SelectImage, then Paint_DrawBitMap, and then EPD_7IN5_V2_Display.
