Esp32 filtering a request at w5500
Hey guys, I'm writing code on an esp32 using a w5500 module and I'm trying to make an http SSL request on my test API , and the problem is in the API response, the code prints all the content on the website and I need it only from the response which is the value 1 (which is the second number among the 3 numbers printed at the end of the console), below I will put the LOG of the responses and all the code for you to view, if anyone knows how I can change it to obtain only I would greatly appreciate the answer!!
the respose:
Begin Ethernet
17:36:32.343 -> DHCP OK!
17:36:37.402 -> Local IP : 192.168.0.148
17:36:37.402 -> Subnet Mask : 255.255.255.0
17:36:37.402 -> Gateway IP : 192.168.0.1
17:36:37.439 -> DNS Server : 192.168.0.1
17:36:37.440 -> Ethernet Successfully Initialized
17:36:38.569 -> connected to Resposta inválida: HTTP/1.1 200 OK
17:36:38.693 -> Server: hcdn
17:36:38.693 -> Date: Tue, 03 Oct 2023 20:36:37 GMT
17:36:38.740 -> Content-Type: application/json
17:36:38.740 -> Transfer-Encoding: chunked
17:36:38.819 -> Connection: close
17:36:38.819 -> Vary: Accept-Encoding
17:36:38.819 -> x-powered-by: PHP/8.1.18
17:36:38.883 -> platform: hostinger
17:36:38.883 -> content-security-policy: upgrade-insecure-requests
17:36:38.959 -> x-turbo-charged-by: LiteSpeed
17:36:39.006 -> x-hcdn-request-id: 2785735fb09b8ebe1898eaf4f2a403c5-asc-edge1
17:36:39.006 -> x-hcdn-cache-status: DYNAMIC
17:36:39.070 -> x-hcdn-upstream-rt: 0.014
17:36:39.070 ->
17:36:39.070 -> 1
17:36:39.070 -> 1
17:36:39.070 -> 0
The base file of the code:
#include <SPI.h>
#include <EthernetLarge.h>
#include <SSLClient.h>
#include "trust_anchors.h"
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "thaianramalho.com";
const int rand_pin = A5;
EthernetClient base_client;
SSLClient client(base_client, TAs, (size_t)TAs_NUM, rand_pin);
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true;
    Serial.println("Begin Ethernet");
    Ethernet.init(5);
    if (Ethernet.begin(mac)) {
        Serial.println("DHCP OK!");
        Serial.println("Failed to configure Ethernet using DHCP");
        if (Ethernet.hardwareStatus() == EthernetNoHardware) {
            Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
            while (true) {
                delay(1);
        if (Ethernet.linkStatus() == LinkOFF) {
            Serial.println("Ethernet cable is not connected.");
        IPAddress ip(192, 168, 1, 28);
        IPAddress dns(192, 168, 1, 1);
        IPAddress gw(192, 168, 1, 1);
        IPAddress sn(255, 255, 255, 0);
        Ethernet.begin(mac, ip, dns, gw, sn);
        Serial.println("STATIC OK!");
    delay(5000);
    Serial.print("Local IP : ");
    Serial.println(Ethernet.localIP());
    Serial.print("Subnet Mask : ");
    Serial.println(Ethernet.subnetMask());
    Serial.print("Gateway IP : ");
    Serial.println(Ethernet.gatewayIP());
    Serial.print("DNS Server : ");
    Serial.println(Ethernet.dnsServerIP());
    Serial.println("Ethernet Successfully Initialized");
    if (client.connect(server, 443)) {
        Serial.print("connected to ");
        client.println("GET /jsonteste.php HTTP/1.1");
        client.println("Host: thaianramalho.com");
        client.println("Connection: close");
        client.println();
        Serial.println("connection failed");
    beginMicros = micros();
    int len = client.available();
    if (len > 0) {
        byte buffer[80];
        if (len > 80) len = 80;
        client.read(buffer, len);
        if (printWebData) {
            Serial.write(buffer, len);
        byteCount = byteCount + len;
        // Verifique se a resposta contém "1"
        if (strstr((char*)buffer, "1") != NULL) {
            Serial.println("deu certo");
            Serial.println("nao deu chefe");
    if (!client.connected()) {
        endMicros = micros();
        Serial.println("disconnecting.");
        client.stop();
        Serial.print("Received ");
        Serial.print(byteCount);
        Serial.print(" bytes in ");
        float seconds = (float)(endMicros - beginMicros) / 1000000.0;
        Serial.print(seconds, 4);
        float rate = (float)byteCount / seconds / 1000.0;
        Serial.print(", rate = ");
        Serial.print(rate);
        Serial.print(" kbytes/second");
        while (true) {
            delay(1);
What do you see on serial monitor?
that was solved, i used the HTTP 1.0 cause its simpler then the 1.1 and did that: void sendHTTPRequest() {
if (client.connect(serverIP, 80)) {
Serial.print("Resposta da API: ");
String url = "/colinas/api_saida_cancela.php?senha=dxic5CyB&&uid=";
url += uidByteStr;
client.println("GET " + url + " HTTP/1.0");
client.println("Host: 192.168.0.30"); // Usando o endereço IP do servidor na rede local
client.println();
Serial.println("Conexão falhou.");
buzzerFeedback();
return;
void processHTTPResponse() {
if (len > 0) {
byte buffer[80];
bool headersReceived = false;
if (!headersReceived) {
  if (strstr((char*)buffer, "\r\n\r\n") != NULL) {
    headersReceived = true;
    httpRequestCompleted = true;
    char* htmlContent = strstr((char*)buffer, "\r\n\r\n") + 4;
    len = len - (htmlContent - (char*)buffer);
    if (len > 0) {
      Serial.write((uint8_t*)htmlContent, len);
      if (strstr((char*)htmlContent, "1") != NULL) {
        Serial.println("Cartão autorizado. Abrindo...");
        lcd.clear();
        lcd.print(" VOLTE SEMPRE ");
        buzzerFeedback();
        digitalWrite(RELE_PIN, HIGH);
        digitalWrite(RELE_PIN, LOW);
        delay(2400);
        lcd.clear();
        Serial.println("Cartão negado.");
        lcd.clear();
        lcd.print("*CARTAO  NEGADO* ");
        buzzerFeedback();
        delay(65);
        digitalWrite(BUZZER_PIN, LOW);
        delay(55);
        buzzerFeedback();
        delay(65);
        delay(2400);
        lcd.clear();
