ESP32 Firebeetle WROOM print to RS232
Hi all, abit of a n00b here, in fact this is my first serious project. What I am making is a BLE proximity detector which will transmit an ASCII string via RS232 from a Firebeetle to a Mobotix IP Camera RS232 interface.
I have a firebeetle and I have connected Rx2 & Tx2 to a MAX232 chip with the output going to the Camera's rs232 module.
So far I have the unit working and triggering a relay, which is great except I want to make it more secure.
This is the code thus far. I have added some stuff which I thought would output to the RS232 but no joy. I would be ever grateful for any advice and or help
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#define LED1 2
String knownBLEAddresses[] = {"00006666-0000-1000-8000-00805f9b34fb", "ff:ff:10:00:fd:8b", "ff:ff:10:06:91:0f"};
int RSSI_THRESHOLD = -60;
bool device_found = false;
bool poximity_confirmed = false;
bool inhibit = false;
int loopCount = 1;
int scanTime = 1; //In seconds
int num_knowndevice = 0;
int p_knowndevice = 0;
BLEScan* pBLEScan;
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
    void onResult(BLEAdvertisedDevice advertisedDevice) {
      int Current_rssi = -88;
      for (int i = 0; i < (sizeof(knownBLEAddresses) / sizeof(knownBLEAddresses[0])); i++)
        //if (strcmp(advertisedDevice.getAddress().toString().c_str(), knownBLEAddresses[i].c_str()) == 0)
        if (strcmp(advertisedDevice.getServiceUUID().toString().c_str(), knownBLEAddresses[i].c_str()) == 0)
          device_found = true;
          Current_rssi = advertisedDevice.getRSSI();
          if (Current_rssi > RSSI_THRESHOLD) {
            num_knowndevice++;
            //poximity_confirmed = true;
      if (device_found) {
        Serial.print(advertisedDevice.getAddress().toString().c_str());
        Serial.print("(");
        Serial.print(Current_rssi);
        Serial.print(")");
          Serial.println(" is confirmed.");
          Serial.println(" is unconfirmed.");
  Serial.begin(9600); //Enable UART on ESP32
  pinMode(LED1, OUTPUT); //make BUILTIN_LED pin as output
  Serial.println("BLE Scanning..."); // Print Scanning
  BLEDevice::init("");
  pBLEScan = BLEDevice::getScan(); //create new scan
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks()); //Init Callback Function
  pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
  pBLEScan->setInterval(100); // set Scan interval
  pBLEScan->setWindow(99); // less or equal setInterval value
  delay(1100);
  if (loopCount >= 1000) loopCount = 1; //Reset loopCount hourly
  if (loopCount % 1 == 0) inhibit = false; //Debouncing Control
  if (!inhibit and poximity_confirmed)
    inhibit = true;
    loopCount = 0; //Set loopCount to 0 to sync the debouncing clock
    digitalWrite(LED1, HIGH);
    Serial.println("On");
    delay(2000);
    Serial.println("Off");
    digitalWrite(LED1, LOW);
  BLEScanResults foundDevices = pBLEScan->start(scanTime, false);
  pBLEScan->clearResults(); // delete results fromBLEScan buffer to release memory
  if (p_knowndevice < num_knowndevice) poximity_confirmed = true;
  p_knowndevice = num_knowndevice;
  loopCount++;
This is the modified code, where I added Serial2.
#define LED1 2
#define RXD2 16
#define TXD2 17
int loopCount = 1;
BLEScan* pBLEScan;
            num_knowndevice++;
      if (device_found) {
        Serial2.print(advertisedDevice.getAddress().toString().c_str());
        Serial2.print("(");
        Serial2.print(Current_rssi);
        Serial2.print(")");
          Serial2.println(" is confirmed.");
          Serial2.println(" is unconfirmed.");
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  Serial.println("Serial Txd is on pin: "+String(TX));
  Serial.println("Serial Rxd is on pin: "+String(RX));
  Serial2.println("BLE Scanning..."); // Print Scanning
  delay(1100);
    inhibit = true;
    Serial2.println("On");
    delay(2000);
    Serial2.println("Off");
  loopCount++;
