ESP32 GPIO27 internal Pull-Up to Detect GND
I’m using an ESP32 and want to configure GPIO27 so that it is HIGH by default and detects when it is connected to GND (LOW state). I know some MCUs have only internal pull-down resistors, but does the ESP32 support internal pull-ups as well?
From my research, I believe I can use INPUT_PULLUP to achieve this. Here’s the code I’m using:
#define PIN 27
    pinMode(PIN, INPUT_PULLUP);
    int state = digitalRead(PIN);
    Serial.println(state ? "HIGH" : "LOW");
Expected Behavior:
  • Nothing connected → GPIO27 reads HIGH
  • GND connected → GPIO27 reads LOW
Does this approach make sense? Is there a better way to achieve this on the ESP32?
40cm cat5e cable will be used and endstop switch on gpio27 and gnd
Thanks for any advice! :blush:
Why not just try it?
Might be better to use an external pull-up if you are in an electrically noisy environment, relays, motors, actuators, 220VAC etc
Should work, but as @jim-p says, it may be advisable to add more externally.
Hint: The pins are undefined at power up/reset until setup/boot loader programs them. I would recommend a pull up resistor.
Yes, but be careful which pins you use. Some of the ESP32 pins don't have any internal pullups. I got bitten by that one before!
