Hello,
I have a problem when I try to connect the ESP with the Google Sheet, like you see in the lines below this message appears when I changed to a router of an Internet provider that has its time 4 minutos shifted. When the ESP connects with a hotspot of the cellphone or another internet provider everything is ok
ESP Google Sheet Client v1.4.4
Token info: type = OAuth2.0 access token, status = on initializing
Token info: type = OAuth2.0 access token, status = error
Token error: code: -111, message: System time or library reference time was not set. Use GSheet.setSystemTime to set time.
Could you send me some advices about it.
Regards,
Jean
