ESP32 Guru Meditation Error with Timer function
I'm a german user and I apologize in advance for my english.
I have tried to programm a Timer funnction wich i outsourced in a .cpp.
Main Programm:
#include "Timer.h"
//*** Hardware ***//
  //** digital out **//
  int i_led_1 = 26;
  int i_led_2 = 27;
  int i_pwm_neg = 32;
  int i_pwm_pos = 33;
  //** analog in **
  int adc_cp  = 4;
  int i_read;
  bool x_start = false;
  bool x_out;
  // set baud for return info
  Serial.begin (115200);
  analogReadResolution(12);
  pinMode(i_led_1, OUTPUT);
  pinMode(i_led_2, OUTPUT);
  pinMode(i_pwm_neg, OUTPUT);
  pinMode(i_pwm_pos, OUTPUT);
  Timer_setup();
  digitalWrite(i_pwm_neg, LOW);
  digitalWrite(i_pwm_pos, HIGH);
  i_read = int( float(analogRead(adc_cp)) * 0.01 + float(i_read) * 0.99 );  // max 4095
    Serial.println("Analogwert:" + String(i_read));
  if (i_read  < 2500 ) {
    digitalWrite(i_led_1, HIGH);
    x_start = true;
    digitalWrite(i_led_1, LOW);
    x_start = false;
  //*** Timer
  Timer_fkt( 0, x_start, 10000, x_out);
  if (x_out == true){
    digitalWrite(i_led_2, HIGH);
    digitalWrite(i_led_2, LOW);
Timer.cpp:
#include "Timer.h"
#include <Arduino.h>
//*** configuration ***
hw_timer_t *timer = NULL;
volatile unsigned long ul_cnt_time;
volatile bool x_blink_ca;
volatile bool x_cach_1;
volatile bool x_cach_2;
//******** ISR function ********
void IRAM_ATTR onTimer(){
  ul_cnt_time = ul_cnt_time + 1;                // count the milliseconds
  x_blink_ca = ! x_blink_ca;
    if ( ul_cnt_time > 4294800000 ) {
      ul_cnt_time = 0;
  Serial.println( "Timer läuft " );
//********** Setup *************
void Timer_setup(){
  // set timer
    // Use 1st timer of 4 (counted from zero).
    // Set 80 divider for prescaler: Quarz 80MHz/80 = 1´000´000 tic/sec = 1000ns = 1us
    // flag = true to count up
    timer = timerBegin(0, 80, true);
    // Attach onTimer function to our timer.
    timerAttachInterrupt(timer, &onTimer, true);
    // Set alarm to call onTimer function every second (value in microseconds).
    // Repeat the alarm (third parameter)
    timerAlarmWrite(timer, 1000 , true);  // repead every 1ms
    timerAlarmEnable(timer);                  // Timer enable
//******* main Function *******
void Timer_fkt( int FUNC, bool IN, int TIMMS, bool OUT) {
  if ( TIMMS > 4294800000 ) {
    TIMMS = 4294800000;
  // set timer funktion
    switch (FUNC) {
      case 0: //TON
              if (IN == false) {
                OUT = false;
                ul_cnt_time = 0;
              } else if ( (IN == true) && (ul_cnt_time < TIMMS) ){
                OUT = false;
              } else if ( (IN == true) && (ul_cnt_time >= TIMMS) ){
                OUT = true;
      case 1: //TOF
              if (IN == false) {
                OUT = false;
                ul_cnt_time = 0;
                x_cach_1 = false;
              } else if ( IN == true ){
                OUT = true;
                ul_cnt_time = 0;
                x_cach_1 = true;
              } else if ( (IN == false) && (ul_cnt_time < TIMMS) && (x_cach_1 = true) ){
                OUT = true;
              } else if ( (IN == false) && (ul_cnt_time >= TIMMS) && (x_cach_1 = true) ){
                OUT = false;
                ul_cnt_time = 0;
                x_cach_1 = false;
      case 2: //TP
              if ( (IN == true) && (x_cach_2 == false) ){
                x_cach_2 = true;
              if ( (x_cach_2 == true) && (ul_cnt_time < TIMMS) ) {
                OUT = true;
              } else if ( (x_cach_2 == true) && (ul_cnt_time >= TIMMS) ) {
                OUT = false;
                x_cach_2 = false;
      case 3: //BLINK
              if (IN == true) {
                OUT = x_blink_ca;
                OUT = false;
Timer.h:
void Timer_fkt ( int, bool, int, bool );
void Timer_setup() ;
every time i get the same error:
Analogwert:112
Analogwert:148
Analogwert:184
Analogwert:220
Timer läuft
Analogwert:256
Analogwert:291
AnaloGuru Meditation Error: Core  1 panic'ed (Interrupt wdt timeout on CPU1)
Core 1 register dump:
PC      : 0x40088946  PS      : 0x00060e34  A0      : 0x80087d6b  A1      : 0x3ffbea60
A2      : 0x3ffb81f0  A3      : 0x3ffb8074  A4      : 0x00000001  A5      : 0x00000001
A6      : 0x00060e23  A7      : 0x00000000  A8      : 0x3ffb8074  A9      : 0x3ffb8074
A10     : 0x00000018  A11     : 0x00000018  A12     : 0x00000001  A13     : 0x00000001
A14     : 0x00060e21  A15     : 0x00000000  SAR     : 0x00000015  EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xfffffffc
Core 1 was running in ISR context:
EPC1    : 0x4008726a  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x40088946
ELF file SHA256: 0000000000000000
Backtrace: 0x40088946:0x3ffbea60 0x40087d68:0x3ffbea80 0x4008639f:0x3ffbeaa0 0x400d2251:0x3ffbeae0 0x400d12b5:0x3ffbeb00 0x400d149e:0x3ffbeb20 0x400d1509:0x3ffbeb40 0x40080f26:0x3ffbeb60 0x4008119d:0x3ffbeb80 0x40083c5d:0x3ffbeba0 0x400d225d:0x3ffb1ef0 0x400d12b5:0x3ffb1f10 0x400d14cd:0x3ffb1f30 0x400d14f1:0x3ffb1f50 0x400d0fbd:0x3ffb1f70 0x400d26e1:0x3ffb1fb0 0x40086565:0x3ffb1fd0
Core 0 register dump:
PC      : 0x40087272  PS      : 0x00060034  A0      : 0x80087a31  A1      : 0x3ffbe520
A2      : 0x3ffbdf84  A3      : 0x0000cdcd  A4      : 0xb33fffff  A5      : 0x00000001
A6      : 0x00060021  A7      : 0x0000abab  A8      : 0x0000cdcd  A9      : 0x3ffc00d8
A10     : 0x00000003  A11     : 0x00060023  A12     : 0x00060021  A13     : 0x3ffbc1b0
A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x0000001f  EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
Backtrace: 0x40087272:0x3ffbe520 0x40087a2e:0x3ffbe550 0x4008664f:0x3ffbe570 0x400887c9:0x3ffbe590 0x40083c66:0x3ffbe5a0 0x400eb1f7:0x3ffbc130 0x400e1cf3:0x3ffbc150 0x400879fa:0x3ffbc170 0x40086565:0x3ffbc190
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Analogwert:38
Analogwert:75
Analogwert:112
Analogwert:149
Analogwert:185
Analogwert:221
Timer läuft
Analogwert:257
Analogwert:292
Backtrace: 0x40088946:0x3ffbea60 0x40087d68:0x3ffbea80 0x4008639f:0x3ffbeaa0 0x400d2251:0x3ffbeae0 0x400d12b5:0x3ffbeb00 0x400d149e:0x3ffbeb20 0x400d1509:0x3ffbeb40 0x40080f26:0x3ffbeb60 0x4008119d:0x3ffbeb80 0x40083c5d:0x3ffbeba0 0x400d2262:0x3ffb1ef0 0x400d12b5:0x3ffb1f10 0x400d14cd:0x3ffb1f30 0x400d14f1:0x3ffb1f50 0x400d0fbd:0x3ffb1f70 0x400d26e1:0x3ffb1fb0 0x40086565:0x3ffb1fd0
Rebooting...
Exception Decoder:
PC: 0x40088946: vListInsert at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/list.c line 188
Decoding stack results
0x40087d68: vTaskPlaceOnEventList at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/tasks.c line 2901
0x4008639f: xQueueGenericReceive at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/queue.c line 1590
0x400d2251: uartWriteBuf at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\esp32-hal-uart.c line 363
0x400d12b5: HardwareSerial::write(unsigned char const*, unsigned int) at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\HardwareSerial.cpp line 175
0x400d149e: Print::write(char const*) at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h line 67
0x400d1509: Print::println(char const*) at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\Print.cpp line 89
0x40080f26: onTimer() at C:\Users\tomgs\iCloudDrive\Firma\ESP32\Probe-Test\Test_10_timer/Timer.cpp.ino line 27
0x4008119d: __timerISR at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\esp32-hal-timer.c line 88
0x400d225d: uartWriteBuf at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\esp32-hal-uart.c line 365
0x400d14cd: Print::print(String const&) at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Print.h line 72
0x400d14f1: Print::println(String const&) at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\Print.cpp line 188
0x400d0fbd: loop() at C:\Users\tomgs\iCloudDrive\Firma\ESP32\Probe-Test\Test_10_timer/Test_10_timer.ino line 36
0x400d26e1: loopTask(void*) at C:\Users\tomgs\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32\main.cpp line 23
0x40086565: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 143
Looks like you have a Serial.print in your ISR, which is likely to give this kind of problem. What happens if you comment out that line?
Don't feel bad; the ESP cores are kind of notorious for throwing the towel in the ring in these kinds of situations. I've had my fair share of kernel panics as well with the ESP32. The watchdog is rather trigger happy; make sure to keep ISR's very tidy and fast.
Better learn what each port of the ESP32's pins are supported by each port and why to use portA for this project and not portB. . Using portB GPIO's improperly will cause issues.
Why not use one of the 4 built in user available hardware timers?
   Chappie Weather upgrade/addition
   process wind speed direction and rain fall.
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include "driver/pcnt.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
#include <ESP32Time.h>
ESP32Time rtc;
WiFiClient wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
float CalculatedVoltage = 0.0f;
float kph = 0.0f;
float rain  = 0.0f;
   PCNT PCNT_UNIT_0, PCNT_CHANNEL_0 GPIO_NUM_15 = pulse input pin
   PCNT PCNT_UNIT_1, PCNT_CHANNEL_0 GPIO_NUM_4 = pulse input pin
pcnt_unit_t pcnt_unit00 = PCNT_UNIT_0; //pcnt unit 0 channel 0
pcnt_unit_t pcnt_unit10 = PCNT_UNIT_1; //pcnt unit 1 channel 0
hw_timer_t * timer = NULL;
#define evtAnemometer  ( 1 << 0 )
#define evtRainFall    ( 1 << 1 )
#define evtParseMQTT   ( 1 << 2 )
EventGroupHandle_t eg;
#define OneMinuteGroup ( evtAnemometer | evtRainFall )
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
SemaphoreHandle_t sema_CalculatedVoltage;
int mqttOK = 0; // stores a count value that is used to cause an esp reset
volatile bool TimeSet = false;
   A single subject has been subscribed to, the mqtt broker sends out "OK" messages if the client receives an OK message the mqttOK value is set back to zero.
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic = topic; //store new topic
    int i = 0; // extract payload
    for ( i; i < length; i++)
      x_message.payload[i] = ((char)payload[i]);
    x_message.payload[i] = '\0';
    xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR(eg, OneMinuteGroup, &xHigherPriorityTaskWoken);
} // void IRAM_ATTR onTimer()
  eg = xEventGroupCreate(); // get an event group handle
  //  x_message.topic.reserve(300);
  adc1_config_width(ADC_WIDTH_12Bit);
  adc1_config_channel_atten(ADC1_CHANNEL_6, ADC_ATTEN_DB_11);// using GPIO 34 wind direction
  adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39 current
  adc1_config_channel_atten(ADC1_CHANNEL_0, ADC_ATTEN_DB_11);// using GPIO 36 battery volts
  // hardware timer 4 set for one minute alarm
  timer = timerBegin( 3, 80, true );
  timerAttachInterrupt( timer, &onTimer, true );
  timerAlarmWrite(timer, 60000000, true);
  /* Initialize PCNT's counter */
  int PCNT_H_LIM_VAL         = 3000;
  int PCNT_L_LIM_VAL         = -10;
  // 1st PCNT counter
  pcnt_config_t pcnt_config  = {};
  pcnt_config.pulse_gpio_num = GPIO_NUM_15;// Set PCNT input signal and control GPIOs
  pcnt_config.ctrl_gpio_num  = PCNT_PIN_NOT_USED;
  pcnt_config.channel        = PCNT_CHANNEL_0;
  pcnt_config.unit           = PCNT_UNIT_0;
  // What to do on the positive / negative edge of pulse input?
  pcnt_config.pos_mode       = PCNT_COUNT_INC;   // Count up on the positive edge
  pcnt_config.neg_mode       = PCNT_COUNT_DIS;   // Count down disable
  // What to do when control input is low or high?
  pcnt_config.lctrl_mode     = PCNT_MODE_KEEP; // do not count if low reverse
  pcnt_config.hctrl_mode     = PCNT_MODE_KEEP;    // Keep the primary counter mode if high
  // Set the maximum and minimum limit values to watch
  pcnt_config.counter_h_lim  = PCNT_H_LIM_VAL;
  pcnt_config.counter_l_lim  = PCNT_L_LIM_VAL;
  pcnt_unit_config(&pcnt_config); // Initialize PCNT unit
  pcnt_set_filter_value( PCNT_UNIT_0, 1); //Configure and enable the input filter
  pcnt_filter_enable( PCNT_UNIT_0 );
  pcnt_counter_pause( PCNT_UNIT_0 );
  pcnt_counter_clear( PCNT_UNIT_0 );
  pcnt_counter_resume( PCNT_UNIT_0); // start the show
  // setup 2nd PCNT
  pcnt_config = {};
  pcnt_config.pulse_gpio_num = GPIO_NUM_4;
  pcnt_config.unit           = PCNT_UNIT_1;
  //pcnt_set_filter_value( PCNT_UNIT_1, 1 );
  //pcnt_filter_enable  ( PCNT_UNIT_1 );
  pcnt_counter_pause  ( PCNT_UNIT_1 );
  pcnt_counter_clear  ( PCNT_UNIT_1 );
  pcnt_counter_resume ( PCNT_UNIT_1 );
  xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
  sema_CalculatedVoltage = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_CalculatedVoltage );
  sema_mqttOK = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 15000, NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fReadBattery, "fReadBattery", 4000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fReadCurrent, "fReadCurrent", 4000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fWindDirection, "fWindDirection", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fAnemometer, "fAnemometer", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fRainFall, "fRainFall", 10000, NULL, 4, NULL, 1 );
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 ); // assign all to core 1
} //void setup()
void fWindDirection( void *pvParameters )
// read the wind direction sensor, return heading in degrees
  float adcValue = 0.0f;
  uint64_t TimePastKalman  = esp_timer_get_time();
  SimpleKalmanFilter KF_ADC( 1.0f, 1.0f, .01f );
  float high = 0.0f;
  float low = 2000.0f;
  float ADscale = 3.3f / 4096.0f;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 100; //delay for mS
  int count = 0;
  String windDirection;
  windDirection.reserve(20);
  String MQTTinfo = "";
  MQTTinfo.reserve( 150 );
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  for (;;)
    windDirection = "";
    adcValue = float( adc1_get_raw(ADC1_CHANNEL_6) ); //take a raw ADC reading
    KF_ADC.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue = KF_ADC.updateEstimate( adcValue ); // apply simple Kalman filter
    TimePastKalman = esp_timer_get_time(); // time of update complete
    adcValue = adcValue * ADscale;
    log_i( "                       adc %f", adcValue );
    if ( (adcValue >= 0.0f) & (adcValue <= .25f )  )
     // log_i( " n" );
      windDirection.concat( "N" );
//    if ( (adcValue >= .25f) & adcValue <= .5f )
//      log_i( " nne" );
//      windDirection.concat( "NNE");
    if ( (adcValue > .25f) & (adcValue <= .6f ) )
    //  log_i( " e" );
      windDirection.concat( "E" );
//    if ( (adcValue > 1.0f) & (adcValue < 1.75f) )
//      log_i( " sse" );
//      windDirection.concat( "S-SE");
//        if ( (adcValue >= 1.75f) & (adcValue < 2.2f) )
//      log_i( " nnw" );
//      windDirection.concat( "N-NW" );
    if ( (adcValue > 2.0f) & ( adcValue < 3.3f) )
   //   log_i( " s" );
      windDirection.concat( "S");
//    if ( (adcValue > 2.6f) & (adcValue < 3.0f ) )
//      log_i( " ssw" );
//      windDirection.concat( "S-SW" );
    if ( (adcValue >= 1.7f) & (adcValue < 2.0f ) )
     // log_i( " w" );
      windDirection.concat( "W" );
    if( count >= 30 )
      MQTTinfo.concat( String(kph, 2) );
      MQTTinfo.concat( ",");
      MQTTinfo.concat( windDirection );
      MQTTinfo.concat( String(rain,2) );
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
      MQTTclient.publish( topicWSWDRF, MQTTinfo.c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
      count = 0;
    count++;
    MQTTinfo = "";
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete ( NULL );
// read rainfall
void fRainFall( void *pvParemeters )
  int16_t count = 0;
  pcnt_counter_pause( PCNT_UNIT_1 );
  pcnt_counter_clear( PCNT_UNIT_1 );
  pcnt_counter_resume( PCNT_UNIT_1 );
  for  (;; )
    xEventGroupWaitBits (eg, evtRainFall, pdTRUE, pdTRUE, portMAX_DELAY);
    pcnt_get_counter_value( PCNT_UNIT_1, &count );
    if ( count != 0 )
      // 0.2794mm of rain per click clear clicks at mid night
      rain = 0.2794f * (float)count;
      log_i( "count %d, rain rain = %f mm", count, rain );
void fAnemometer( void *pvParameters )
  int16_t count = 0;
  pcnt_counter_clear(PCNT_UNIT_0);
  pcnt_counter_resume(PCNT_UNIT_0);
  for (;;)
    xEventGroupWaitBits (eg, evtAnemometer, pdTRUE, pdTRUE, portMAX_DELAY);
    pcnt_get_counter_value( PCNT_UNIT_0, &count); //int16_t *count
    // A wind speed of 2.4km/h causes the switch to close once per second
    kph = 2.4 * ((float)count / 60.0f);
    //if ( count != 0 )
      log_i( "count %d, wind Kph = %f", count, kph );
    count = 0;
    pcnt_counter_resume( PCNT_UNIT_0 );
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 60;
  for (;;)
    vTaskDelay( 1000 );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
  vTaskDelete( NULL );
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      // parse the time from the OK message and update MCU time
      if ( String(px_message.topic) == topicOK )
        if ( !TimeSet)
          String temp = "";
          temp =  px_message.payload[0];
          temp += px_message.payload[1];
          temp += px_message.payload[2];
          temp += px_message.payload[3];
          int year =  temp.toInt();
          temp = "";
          temp =  px_message.payload[5];
          temp += px_message.payload[6];
          int month =  temp.toInt();
          temp =  "";
          temp =  px_message.payload[8];
          temp += px_message.payload[9];
          int day =  temp.toInt();
          temp = "";
          temp = px_message.payload[11];
          temp += px_message.payload[12];
          int hour =  temp.toInt();
          temp = "";
          temp = px_message.payload[14];
          temp += px_message.payload[15];
          int min =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "rtc  %s ", rtc.getTime() );
          TimeSet = true;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
    mqttOK = 0;
} // void fparseMQTT( void *pvParameters )
void fReadCurrent( void * parameter )
  float ADbits = 4096.0f;
  float ref_voltage = 3.3f;
  float offSET = .0f;
  uint64_t TimePastKalman  = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
  SimpleKalmanFilter KF_I( 1.0f, 1.0f, .01f );
  float mA = 0.0f;
  int   printCount = 0;
  const float mVperAmp = 100.0f;
  float adcValue = 0;
  float Voltage = 0;
  float Power = 0.0;
  String powerInfo = "";
  powerInfo.reserve( 150 );
    vTaskDelay( 250 );
  const TickType_t xFrequency = 1000; //delay for mS
  for (;;)
    adc1_get_raw(ADC1_CHANNEL_3); // read once discard reading
    adcValue = ( (float)adc1_get_raw(ADC1_CHANNEL_3) );
    Voltage = ( (adcValue * ref_voltage) / ADbits ) + offSET; // Gets you mV
    mA = Voltage / mVperAmp; // get amps
    KF_I.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    mA = KF_I.updateEstimate( mA ); // apply simple Kalman filter
    printCount++;
    if ( printCount == 60 )
      xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY);
      Power = CalculatedVoltage * mA;
      log_i( "Voltage=%f mA=%f Power=%f", CalculatedVoltage, mA, Power );
      printCount = 0;
      powerInfo.concat( String(CalculatedVoltage, 2) );
      powerInfo.concat( ",");
      powerInfo.concat( String(mA, 2) );
      powerInfo.concat( String(Power, 4) );
      MQTTclient.publish( topicPower, powerInfo.c_str() );
      powerInfo = "";
} //void fReadCurrent( void * parameter )
void fReadBattery( void * parameter )
  //float ADbits = 4096.0f;
  //float ref_voltage = 3.3f;
  float offSET = 0.0f;
  const float r1 = 50500.0f; // R1 in ohm, 50K
  const float r2 = 10000.0f; // R2 in ohm, 10k potentiometer
  //float Vscale = (r1+r2)/r2;
  float Vbatt = 0.0f;
  int printCount = 0;
  float vRefScale = (3.3f / 4096.0f) * ((r1 + r2) / r2);
  SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
  for (;;)
    adc1_get_raw(ADC1_CHANNEL_0); //read and discard
    adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading
    KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
    adcValue = KF_ADC_b.updateEstimate( adcValue ); // apply simple Kalman filter
    Vbatt = adcValue * vRefScale;
    xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY );
    CalculatedVoltage = Vbatt;
//        printCount++;
//        if ( printCount == 3 )
//        log_i( "Vbatt %f", Vbatt );
//        printCount = 0;
    //log_i( "fReadBattery %d",  uxTaskGetStackHighWaterMark( NULL ) );
void MQTTkeepalive( void *pvParameters )
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
void connectToWiFi()
  int TryCount = 0;
  //log_i( "connect to wifi" );
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void connectToMQTT()
  MQTTclient.setKeepAlive( 90 ); // needs be made before connecting
  byte mac[5];
  WiFi.macAddress(mac);
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    // boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
} // void connectToMQTT()
void loop() {}
Example of hardware timer use.
