Hello ,
I am using ESP32 Wroom module.
I have connected successfully both BLE and Mqtt at a same time.
Actually , memory leaks starts when BLE is connected .
There's no issue when executed seperately.
Please Help me with the solution to free the heap memory.
I tried
- ESP_bt release
From looking at the code, well formatted in code tags, you posted, I guess that the code on line number is wrong.
How do you know you are having a memory leak issue? Are you using freeRTOS and assigning a task to core0? And looking at that code, formmated and in code tags, on line 7892 are you sure the syntax is correct?
Idahowalker:
I am using ESP.getfreeHype() to know the actual heap size after each operation.
