ESP32: Help with an led matrix project
Hi everyone,
I have been trying to set up a 16 X 16 led matrix (WS2812b) to my ESP32- WROOM. The goal is to simulate LED dots falling along with gravity and to do this I used an ADXL335 accelerometer to measure the tilt angles. I'll upload my code below:
#include "FastLED.h"
#define LED_PIN 16             // where panel Din is connected.
#define LED_COUNT 20          // Number of leds you want to have active at all times
#define MATRIX_SIZE 16
CRGB leds[LED_COUNT];
const int x_out = A0;
const int y_out = A3;
const int z_out = A6;
const int sampleSize = 10;
int ReadAxis(int axisPin)
  long reading = 0;
  analogRead(axisPin);
  delay(1);
  for (int i = 0; i < sampleSize; i++)
    reading += analogRead(axisPin);
  return reading/sampleSize;
const int xo = ReadAxis(x_out)/10;
const int yo = ReadAxis(y_out)/10;
const int zo = ReadAxis(z_out)/10;
struct Dot {
  float x;
  float y;
  float velocityX;
  float velocityY;
Dot dots[LED_COUNT];
  delay(50);
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, LED_COUNT);
  FastLED.setBrightness(50); //Number 0-255. Prefer 25 -50 ig to decrease current consumption
  // Initialize dots
  for (int i = 0; i < LED_COUNT; i++) {
    dots[i].x = random(0,MATRIX_SIZE);      // somewhere in the matrix
    dots[i].y = random(0,MATRIX_SIZE);     // just defining all points here. They don't light up
    dots[i].velocityX = 0;
    dots[i].velocityY = 0;
bool checkCollision(int dotIndex) {
    if (i != dotIndex) {
      float distance = sqrt(pow(dots[i].x - dots[dotIndex].x, 2) + pow(dots[i].y - dots[dotIndex].y, 2));
      if (distance < 1) { // Adjust collision threshold as needed
        return true; // Collision detected
  return false; // No collision
  float gravity = 9.8; // Earth's gravity, adjust if needed
  float dotSpeed = 0.05; // Adjust dot movement speed
  int xAccel = analogRead(x_out) / 10;    //Not using the AXDL335 library or anything
  int yAccel = analogRead(y_out) / 10;
  int zAccel = analogRead(z_out) / 10;
  xAccel  = xAccel - xo;
  yAccel  = yAccel - yo;
  zAccel  = zAccel - zo;
  // Calculating Tilt angle
  float tiltX = map(xAccel, -50, 50, -90, 90); // prefer - 50 to 50 because that is how much change in reading occurs when tilted -90 or +90 degrees
  float tiltY = map(yAccel, -50, 50, -90, 90);
  // Update dot velocities based on tilt angles
    dots[i].velocityX += tiltX * dotSpeed;
    dots[i].velocityY += tiltY * dotSpeed;
    dots[i].x += dots[i].velocityX;
    dots[i].y += dots[i].velocityY;
    // Check for collisions with edges
    if (dots[i].x < 0 || dots[i].x >= MATRIX_SIZE) {
      dots[i].velocityX *= 0;
      dots[i].x = constrain(dots[i].x, 0, MATRIX_SIZE - 1);
    if (dots[i].y < 0 || dots[i].y >= MATRIX_SIZE) {
      dots[i].velocityY *= 0;
      dots[i].y = constrain(dots[i].y, 0, MATRIX_SIZE - 1);
    // Check for collisions with other dots
    if (checkCollision(i)) {
  // Set LED colors by position
    int ledX = round(dots[i].x);
    int ledY = round(dots[i].y);
    int ledIndex = ledX + (MATRIX_SIZE - 1 - ledY) * MATRIX_SIZE; // Convert coordinates to LED index
    // Set LED color to red
    leds[ledIndex] = CRGB::Red;  // the change will be here to set custom colors. for now, set to red
  // Show the updated LED pattern
  FastLED.show();
  delay(100);          // control delay speeds to control animation speed
There are no errors during compilation. I have double-checked the connection and used a 5V 2A power source, which is why I want to keep the number of LEDs lit low and also its brightness low.
The accelerometer Vcc is connected to the 3.3V pin on the ESP32 and all components are grounded.
However, the LEDs don't light up and I cannot seem to figure out why. Any help is very much appreciated. If you need any more information, please let me know. If I am in the wrong forum, please redirect me.
Thank you for your time
So go back a few steps. Forget about the accelerometer.
Set a simple sketch with just one WS2812b LED - can you control that?
Having done that, move on to, say, controlling one row (or column) of LEDs
Having done that, move on to the full matrix - just making sure you can individually control each LED.
Then try patterns - static first, then animated.
Then try basic accelerometer reading - just printing out to the serial port.
Finally, when all the elements are working, then is the time to bring it all together!
Thanks @awneil for the suggestion. I did just that and tried each component. I had initially checked the led matrix by running randomized patterns and animations. When I tried to control each lead individually, I figured out that my LED matrix that I bought was zig-zag arranged.
In case it helps anyone, the correct equation to find the right ledIndex is given below:
ledIndex = ledY * MATRIX_SIZE + (ledY % 2 == 0 ? ledX : (MATRIX_SIZE - 1 - ledX));
Separately, the accelerometer seems to be working fine. It is really sensitive though, and sometimes the analog readings fluctuate a lot, and I'm not sure why yet.
