I am attempting to use an esp32 dev board to control a fan and light using HomeSpan library example 03 CeilingFanWithLight. The sketch compiles as pasted but I can't figure out where and how to insert the gpio number to make the example actually drive a relay to control the end device. I get an error message if I try compiling the code with
new Service::Fan(16); for example and don't know where to insert the pin number in the example to actually control a fan or light.
// HomeSpan: A HomeKit implementation for the ESP32 //
// Example 3: A simple on/off ceiling fan with an //
// on/off ceiling light //
#include "HomeSpan.h" // Always start by including the HomeSpan library
// Example 3 shows how adding multiple Services to a single Accessory allows us to create a multi-featured Accessory, such as a ceiling fan wih a ceiling light
Serial.begin(115200); // Start a serial connection - this is needed for you to type in your WiFi credentials
homeSpan.begin(Category::Fans,"HomeSpan Ceiling Fan"); // Initialize HomeSpan - note the Category has been set to "Fans"
// We begin by creating a Light Bulb Accessory just as in Examples 1 and 2
new SpanAccessory(); // Begin by creating a new Accessory using SpanAccessory(), no arguments needed
new Service::AccessoryInformation(); // HAP requires every Accessory to implement an AccessoryInformation Service, with the required Identify Characteristic
new Characteristic::Identify(); // Create the required Identify
new Service::LightBulb(); // Create the Light Bulb Service
new Characteristic::On(); // This Service requires the "On" Characterstic to turn the light on and off
// Now we add a Fan Service within this same Accessory
new Service::Fan(); // Create the Fan Service
new Characteristic::Active(); // This Service requires the "Active" Characterstic to turn the fan on and off
// Similar to Example 2, we will also implement a LightBulb as a second Accessory
// If everything worked correctly you should now see two Tiles in the Home App:
// * a Tile named "HomeSpan Ceiling Fan" with an icon of a Fan. Clicking this Tile should open the
// control page showing a Fan control on the left, and a Light control on the right
// * a Tile named "HomeSpan Ceiling Fan 2" with an icon of a LightBulb. Clicking this Tile should
// toggle the Light On/Off
// The reason for including the second LightBulb Accessories in this example is to illustrate the impact of the device's Category
// on various icons. Setting Category to Fan in homeSpan.begin() serves two purposes. First, it sets the icon for the device itself,
// as shown by the Home App during initial pairing, to a Fan. Second, it helps the Home App to determine which icon to use for an
// Accessory Tile when there is ambiguity. The second Accessory contains nothing but a LightBulb Service, so the Home App sensibly
// uses a LightBulb icon for the Tile. But what icon should the Home App use for the first Accessory containing both a Fan Service
// and a LightBulb Service? Either a Fan or LightBulb icon would make sense. Setting the Category of the device to Fan causes
// the Home App to choose a Fan icon for the first Accessory.
// As a test of this, unpair the device; change the Category to Lighting (as in Example 2); re-load the sketch; and re-pair the device.
// You should now see the icon for the "HomeSpan Ceiling Fan" Tile is a LightBulb, and the control screen for the Accessory should
// show the Light control on the left and the Fan control on the right.
// IMPORTANT: HomeKit Controllers often cache a lot of information. If your Controller does not update to match the above configuration,
// simply select the Accessory in your Controller and under settings, select "Remove Accessory", but BEFORE re-pairing the device, type
// 'H' into the HomeSpan CLI. This forces HomeSpan to reboot and generate a new device ID so that it will look "brand new" to the Home App
// when you re-pair.
} // end of setup()
void loop(){
homeSpan.poll(); // run HomeSpan!
} // end of loop()type or paste code here
